Anyone got a link to the original product details? Got to order a full set of bits to build one up, so need to know seatpost/headset sizes for it.
Cane Creek Double Barrel Air Rear Shock For El Guapo 26/ Black / 215mm / 63mm / 21.8mm x 8mm
34.9mm front mech clamp, so same size seat clamp, and that implies 31.6mm seatpost.
The headset on the original frame package was a Smoothie Mixer so that should be external-cup, tapered.
Hope that helps
sq225917 - Member
Cane Creek Double Barrel Air Rear Shock For El Guapo 26/ Black / 215mm / 63mm / 21.8mm x 8mm34.9mm front mech clamp, so same size seat clamp, and that implies 31.6mm seatpost.
Hope that helps
Mot exactly - 30.9 seatpost bikes have 34.9 clamps too - and the PX US Site lists 30.9
And there's a bunch of different external tapered headset size.... 44, 49 and 56 can all be external tapered.
Yeah - Titus site has the below, just not sure it marched On-One, there were several versions
Seatpost: Ø30.9mm
Seatpost Clamp: 35mm
Bottom Bracket: 73mm threaded
Front Mech: 34.9 - top clamp top pull
Headset Type: Mix Taper 44/49.6
- See more at: http://www.titusti.com/bikes/all-mountain/el-guapo/#sthash.DDWlwak1.dpuf
