EDC Tool - Regret i...
[Closed] EDC Tool - Regret it?
33 Users
Just wondering if anyone invested in the EDC tool and regretted it? Thinking about getting one, and all the reviews seem good. Any negatives about the tool at all??
Posted : 11/02/2019 5:19 pm
No, it's ace. Saved my bacon several times. Packless riding on shortish rides rocks.
Posted : 11/02/2019 5:23 pm
 tish
As above, love mine.
Posted : 11/02/2019 5:31 pm
Got two, no regrets. Have a go with the quick link splitter though, it can be tricky to use if you've not practiced before.
Posted : 11/02/2019 6:15 pm
I almost had a warrant refused by Fox because I'd installed one
Claim was nothing to do with the steerer
Common sense prevailed in the end after we'd had the conversation of me going away and cutting the threaded bit off and returning with it.
Worth thinking about
Brilliant tool and really handy though.
Posted : 11/02/2019 6:23 pm
@singlespeedstu - thats a little worrying, were they not going to accept it while it had the thread in there?
Posted : 11/02/2019 6:34 pm
Very good, one less piece of metalwork in a bag or pocket.
Posted : 11/02/2019 6:35 pm
Mine seems really good. If I could go back in time I think a custom frame bag filled with all the stuff I already own might be more versatile.
Posted : 11/02/2019 7:53 pm
 SOAP
Had mine over a year now and can be pretty difficult to get out at times.
Posted : 11/02/2019 8:20 pm
Maybe try a little silicon grease on the o-ring.
Posted : 11/02/2019 8:23 pm
Bit of oil o the o-ring sorts that.
It really is very good. I swap it between 3 bikes having bought the top cap for each one. Expensive but means I always have it with me.
Posted : 11/02/2019 8:24 pm
Absolutely chuffed with mine. Can definitely recommend.
Posted : 11/02/2019 8:38 pm
Brilliant little things.
Tap available for rent of anyone wants to fit one...
Posted : 11/02/2019 9:20 pm
Basically yes that was the jist of the conversation.
I actually took the fork in myself and handed it over the counter. He filled in all the paper work then took the fork off me and removed the paper that i'd put in the top of the steerer with my details on.
Then told me they couldn't help me.
We then had the cutting the steerer down conversation and they did the work anyway.
Think if i'd just posted the fork it they'de have just sent it back with no work done on it.
TBF
It is actually specifically listed in the warranty T's and C's.
Anyone in the West Mids wants to use the threading tool is more than welcome to borrow mine for a couple of beers.
Posted : 11/02/2019 9:27 pm
if you are worried about warranties Spesh do a similar version that doesn't need a thread tapping...
Posted : 12/02/2019 7:27 am
and is £90!
Posted : 12/02/2019 8:44 am
No regrets here - awesome little tool - after having one I can't understand people not having one!
Posted : 12/02/2019 8:50 am
I have one inside the pump which is attached to my frame. This seems ideal. If you have it in the steerer, do you not still have to carry a pump?
Posted : 12/02/2019 8:56 am
TBH I wondered why the EDC relied on threading, when it could have been a bolt through thing like the specialized one, or even bolt onto a sepecific pacific (sic) depth set star fangled nut. Remember we used to bu stuff like this to tighten up our headsets instead of a star fangled tool? I can t find it but its the same principle as the Spesh one.
Posted : 12/02/2019 8:57 am
Yes you do, but the pump I have is tiny where as the EDC pump is huge.
Posted : 12/02/2019 9:02 am
It is simple, light weight, effective and easily adjustable on the trail if necessary. Hard to beat. Only downside is the expense of the whole set up and the possibility for fork warranty hassle though any half decent company wouldn't try to dodge warranty work unless cutting the thread were the cause of the issue
Posted : 12/02/2019 9:07 am
It isn't skinny but that girth makes it pretty effective. Have to admit I'm such a OneUp fanboi I have the EDC in my steerer AND the small pump with a gas cart inside on my frame
Posted : 12/02/2019 9:11 am
No doubt it works, its just massive.
Worth noting that a CO2 canister does not fit inside Lyriks, also find the small canisters not big enough for mtb tyres.
Posted : 12/02/2019 9:32 am
the 70cc pump isn't that massive, its really no bigger than my lezyne mini pump? unless your referring to the 100cc one of course
Posted : 12/02/2019 10:08 am
"Worth noting that a CO2 canister does not fit inside Lyriks, also find the small canisters not big enough for mtb tyres."
Co2 on an EDC tool fits in my Lyriks...
Posted : 12/02/2019 10:37 am
Weird, the CO2 canister definitely does not fit inside my lyriks, 2017 model I think. It does fit in my pikes though. Sure I read somewhere that it doesn't fit Lyriks but can't find a link.
Posted : 12/02/2019 10:51 am
I recently put an EDC in my Marzocchi steerer with some tyre bacon strips in the extra bit and a 100cc pump in my bum bag and one on the gravel commmuter. Great little things, I've been caught out a few times of having no tool after stopping using backpacks for most riding.
Posted : 12/02/2019 10:56 am
Also, you can put things inside the pump, which makes you wonder why no one thought of this before.
Posted : 12/02/2019 10:57 am
I really like mine, I have a 70cc pump and an EDC tool, I have shortened the storage container so that it fits inside the shorter pump, in the container I have a home made tubeless plug kit.
As I have a couple of bikes I wanted to have the tool and pump combo but didn't fancy the massive 100cc pump, the 70cc pump fits nicely in some of my shorts pockets or doesn't feel quite so intrusive when I stick it in my SWAT bib pockets.
Posted : 12/02/2019 11:10 am
I've got the edc tool in the steerer and a fork cork in the bottom of the steerer. In there I have a small blade for trimming tyre inserts a co2 head by topeak and some plastic notes.
Under the saddle I have a tube and two co2 cartridges in a dry bag held in place with a Louri strap. Then I have a set of Sahmurai SWORDS 2.0 in the handle bars. That's me sorted. Just chuck a bottle of water in the cage and I'm away for a quick ride.
Note to self, start going out for quick rides
Posted : 12/02/2019 11:21 am
I nearly pulled the trigger on of those tools! I found this tool for £16..
crank multi tool
It works well and its a nice cheap alternative.
Posted : 12/02/2019 11:29 am
bigmantrials - interested to see some pics or description if possible - that sounds ideal - im gonna get the 70cc pump with tool - then if I could somehow add in a tyre plugger too that would be perfecto!
Posted : 12/02/2019 11:41 am
Anyone make tool kits to fit in the seat tube?
I was thinking about this when trying to find a permanent dry home for 4 x 18650 Li batteries.
Posted : 12/02/2019 11:52 am
Milkie - Like that crank option. Any chance of a link?
Thanks
Posted : 12/02/2019 11:53 am
"Weird, the CO2 canister definitely does not fit inside my lyriks, 2017 model I think. It does fit in my pikes though. Sure I read somewhere that it doesn’t fit Lyriks but can’t find a link."
a quick google says Co2 doesn't fit the boost. Mine are 2017 non-boost (with a 16g cartridge), so thats probably it.
Milkie – Like that crank option. Any chance of a link?
Yup, here it is.... Damn its even cheaper now! £8
Cheap Crank Multitool
Posted : 12/02/2019 12:02 pm
The EDC is so good, that I even stuff it in my jersey pocket when out on the CX bike (carbon steerer).
Posted : 12/02/2019 12:04 pm
Wow...good value Milkie. Plus I'm guessing the cheap aspect is the bits, which are replaceable anyway
Thanks
Posted : 12/02/2019 12:20 pm
Milkie
Member
Have you actually tried it? Worth actually taking it over the different bolts on your bike. e.g. I can't tighten brakes using mine as it fouls the caliper. Also, the top fell off one I bought
Posted : 12/02/2019 12:27 pm
I have the specialised version which is also a good alternative
Posted : 12/02/2019 12:33 pm
You can tap the carbon steerer (carefully), as long as the EDC fits inside it works.
Posted : 12/02/2019 2:00 pm
Have you actually tried it? Worth actually taking it over the different bolts on your bike. e.g. I can’t tighten brakes using mine as it fouls the caliper. Also, the top fell off one I bought
I use mine quite a bit as it's a lot closer to hand than the tools in the garage. What part of your brakes are you trying to tighten? I don't think mine fouls anything as its about the same size as the multitool it replaced. The bits seem OK, the fit is good, not perfect, but a lot better than a £4 multi tool.
I did contemplate re-designing and 3D printing the body to make an extra lightweight version, but I couldn't figure how to dismantle it, I think it might be glued as well as bolted.
Posted : 12/02/2019 2:45 pm
Problem with that gear best one is that its a rip off of someone else's design.
Posted : 12/02/2019 2:46 pm
Lower calliper bolt on a Sram Guide. Can’t get near it
Posted : 12/02/2019 3:34 pm
Does the EDC tool fit in a non-tapered steerer? I would like one and it would be useful if it could also work on my road bike which is 1 1/8th.
Posted : 12/02/2019 5:53 pm
No, it only fits some/most tapered aluminium steerers: https://www.oneupcomponents.com/pages/fork-compatibility
Posted : 12/02/2019 5:58 pm
The tool will fit but the bung and therefore the recess that holds the carry compartment on the bottom will not fit.
Pretty easy to work around though.
Posted : 12/02/2019 6:00 pm
For anyone that's interested, this is my modified EDC container. I cut the container down and used araldite to join it back together so that I could fit it in the 70cc pump.
EDC1
EDC2
I then made a tubless plug kit by cutting the threaded section off a CO2 canister, cutting the handle off a tubeless plug tool and soldering them together. There is just enough room for one loaded worm and then 3 short ones inside the canister.
EDC3
Posted : 12/02/2019 7:10 pm
Milkie
Member
Yup, here it is…. Damn its even cheaper now! £8
Cheers, ordered a couple of those.👍
Posted : 13/02/2019 2:22 am
Bigmantrials
Subscriber
For anyone that’s interested, this is my modified EDC container. I cut the container down and used araldite to join it back together so that I could fit it in the 70cc pump.
Some top modding there mate!
Posted : 13/02/2019 2:27 am
THe crank tool is not nearly as good, had two from ali express, lost one when i fell off and the bike landed on its side, shot out and i didn't notice. Second one bent when i was trying to remove my front wheel. Average tool, not comparable to EDC, is a whack cheaper though!!
Posted : 13/02/2019 6:26 am
There was a suggestion at one point, of a dynaplug adaptor to fit the bottom of the edc. I gave up and just got the sahmurai sword instead.
Posted : 13/02/2019 7:21 am
nice work there bigmantrails - question without modding the end cap thing - does the official one up tire plug and bits fit into that capsule without any modding at all??
Posted : 13/02/2019 8:44 am
Oscillate Wildly - Unfortuantely I don't know, I would have purchased the official oneup plug kit but it was out of stock at the time and I was impatient and wanted to get my setup sorted.
I am sure if Oneup made a smaller capsule that would fit in the smaller pump they would sell a few, even if it was just as a safe place for additional quick links or some cash.
Posted : 13/02/2019 10:45 am
Problem with that gear best one is that its a rip off of someone else’s design.
Indeed, cheap knock off tat.
Here's the real one that now has a chain splitter:
https://allinnmultitools.myshopify.com/products/all-in-multitool-v2-black
Posted : 13/02/2019 10:48 am
Bigmantrials
Subscriber
Oscillate Wildly – Unfortuantely I don’t know, I would have purchased the official oneup plug kit but it was out of stock at the time and I was impatient and wanted to get my setup sorted.
nice one bud- infact the 70cc one doesnt even come with a capsule does it? it states that it can fit the edc tool (no capsule) or a c02 cartridge? can you confirm if yours did come with the capsule thing for a bit of storage along with the tool inside?
Posted : 13/02/2019 11:00 am
Oscillate Wildly
Member
The capsule only comes in one size as far as I can see, and it comes with the tool, not the pump. My understanding is that the 70cc pump will fit either the tool on its own or a CO2 cartridge on its own screwed into the pump cap.
There is a gap between the bottom of the tool/CO2 but if you just stuck stuff in there you might not be able to fish it out, which is why I made the shortened capsule.
Posted : 13/02/2019 1:00 pm
Bigmantrials
Subscriber
Oscillate Wildly
Member
Bigmantrials
ahh i see - so there is space at the bottom but not for the full size capsule that comes wit the tool - hence the mod...interesting there is some space there though youd think they utilise it for extra storage or a plug that can fit in there
Posted : 13/02/2019 1:14 pm
Turn pump upside down and shake.
Works for me.😎
All I keep in there is a few tyre worms.
Bodger tool is one of these with the handle cut down threaded into the end of the multi tool.
https://www.gooutdoors.co.uk/genuine-innovations-tubeless-tyre-repair-kit-p449385?gclsrc=aw.ds&&gclid=Cj0KCQiAnY_jBRDdARIsAIEqpJ1XxTXAXmWuldUFibVq31Ho4ZDikAan_Gww2bd5d43MDhQYz6agicQaAksDEALw_wcB
Posted : 13/02/2019 5:50 pm
Daredn't
Posted : 13/02/2019 5:57 pm
The 2 Gearbest copies turned up today.
Not bad for £8 to be honest!
Posted : 26/02/2019 5:21 pm
