Eccentric Dropouts ...
[Closed] Eccentric Dropouts - why isn't this method used more!?
9 Users
[url= ]null[/url]
Looks very clean method for adjusting things, never seen before and pinched this from retro bike forum.
Posted : 31/07/2015 4:19 pm
Very little throw.
Posted : 31/07/2015 4:28 pm
Gut reaction is it might be difficult to line up the wheel with two independent eccentrics.
Posted : 31/07/2015 4:30 pm
Cost V slotted?
Posted : 31/07/2015 4:37 pm
Can i hear a creak ? - plus the same can be achieved much neater with an eccentric bb.
I like paragon style sliders
Posted : 31/07/2015 4:54 pm
Cost, fragility, complexity etc etc. Alignment should be okay with the graduations
Posted : 31/07/2015 6:00 pm
Just thought they looked pretty neat.
Posted : 31/07/2015 6:04 pm
Also,you've got to align the caliper as the hub moves somehow. I like rockers (blackcat/salsa)
Posted : 31/07/2015 7:02 pm
Rorschach - Member
Very little throw.
It's for a belt drive, so it doesn't need much. The belt will break long before there's enough wear to create a problem with adjustment range.
Posted : 31/07/2015 10:00 pm
Why is'nt this method used more?
Hopefully they've done the maths right for the stay length/ratio/limited belt lengths.
Been there,sweated that (it worked btw)
Posted : 31/07/2015 10:33 pm
[quote=Rorschach ]Also,you've got to align the caliper as the hub moves somehow. I like rockers (blackcat/salsa)
I'm assuming that works automatically, but it's another bit which doesn't seem simple.
Posted : 31/07/2015 11:38 pm
It's easy enough, just align the wheel in the frame by sighting from behind when making big adjustments, then smaller ones as the chain wears are just a 1/4 turn on each screw.
Posted : 04/08/2015 12:39 pm
