EC56 headset cup - ...
[Closed] EC56 headset cup - does it exist
4 Users
Other than an angleset does anybody make an external 56mm dia headset cup? Or a 10mm thick crown race would also work 😕
Responses from the hive mind much appreciated!
P
Posted : 01/10/2013 8:56 pm
No one? I thought I was just being crap with google........
Posted : 01/10/2013 9:45 pm
No not that I know of - 56mm od is for integrated cups, not seen anything that could fit an external cup into that
Posted : 01/10/2013 9:56 pm
44mm is the usual OD for external cups and tapered steerers. What frame is it for?
Posted : 02/10/2013 12:49 pm
I'd really like a Banshee Spitfire but it is designed around 160mm/545 a-c forks with a ZS56 lower cup.
I have 150mm/530mm a-c revs and can't afford new forks as well as the frame so was looking to see if you could get an external cup for a 56 head tube to add a bit of stack height until the budget stretched to new forks as the BB height is already low on Spitfires.
Posted : 02/10/2013 1:17 pm
[url= http://www.hopetech.com/webtop/modules/_repository/documents/HOPEHEADSETS2011Web.pdf ]Hope headset guide[/url] agrees with that.
Posted : 02/10/2013 1:18 pm
The hope headset guide only states what they make not what is possible 😉
There is no reason you couldn't have an EC56 cup other than bike manufacturers not designing for it. Canecreek do a EC56 lower cup for their angleset but that is rather pricey and I don't want to change the geometry. I just wondered if they also existed in "normal" style headsets.
Posted : 02/10/2013 1:48 pm
