So the number of failures being talked about in that other thread made me think this topic is deserving of its own thread...
I am wondering, are all the failures because of water ingress? If not then how come they are failing? I mean my Bosch washing machine goes on at least once a day and the last one lasted 10 years so I can't believe it's the motor itself that is the problem. I'd be interested to hear what is actually experienced by people who have said they have suffered a motor failure. Does it just stop turning or seize. Does it make a noise first and then sound like a bag of spanners etc etc. What has the Bosch/Shimano/Brose service centre said when they have looked at it?
Not had a failure on my e8000 motor yet(2k miles sor far) but a mate has had his '20 reign e in the shop now at least 5 times in the year he's owned it.
At least 4 button control modules
1 motor due to cracked motor casing
Currently waiting for new wiring and battery due to water ingress
Bosch cx gen 4 :failed after 550 miles, just turned it on to go for a ride and it threw a 550 error, which according to the manual is an improper load error, but from chatting to the bosch dealer it means a short circuit was detected. Motor still ran fine, no untoward noises etc, but threw the error every time it was switched on. Some speculation on another forum that 550 errors are caused by water ingress corroding the circuit board inside the motor casing. One chap with the same error took his motor apart and found water and noticed corrosion on the circuit board.
For mine, Bosch replaced with a new motor under warranty, but won't say what caused the fault.
Motor was used in all conditions, but never submerged and never jet washed.
If there’s water in your washing machine motor, then you have a serious problem!
Also ebike motors are not just motors and gears in a casing, there is a whole load of electronics in there, micro processors, sensors etc etc.
So when people say the motor failed, they mean the drive unit, which has the motor, the gears, and all the electronics and sensors in a single unit.
I reckon when water gets in, it's the electronics that fails first in most cases, not the motor itself.
I have to say, I'd be surprised if the boards inside the motors don't have some sort of conformal coating on them - I believe the main board inside the Levo batteries does, so I'd imagine the Brose/Specialized motors would at the least.
Have a look towards the middle of this thread for some photos of the inside of bosch gen 4 Cx drive unit and corrosion on the pcb
https://www.emtbforums.com/community/threads/bosch-gen-4-error-code-550.13197/
My mates Levo has been in and out of dealers quite a few times, for a 1 year old bike, with "motor" issues. After getting a Christmas tree's worth of lights going off they found moisture and dirt in the compartment where the circuit board was housed. All replaced and repaired under warranty, but to be honest with how we (the MTB community in general) ride our bikes and the UK weather we shouldn't be surprised at the number of this type of problem. Add to that hose pipe cleaning, or god forbid a pressure washer (!), and water ingress is inevitable I think.
3 Spesh bikes
2017 Levo, new motor due to water ingress, my fault due to bad washing technique, bearings were rough and notchy, replaced under warranty via the dealer
2018 Kenevo, hard pedal strike, crank arm could be moved in and out, no idea what had broke, even Spesh dont know as they are not allowed to open the motor up, they have to go back to Brose to be inspected, motor was replaced under warranty via the dealer
2020 Levo, riding along and all of a sudden no drive and a screeching noise, dealer said it was the sprag clutch and drive belt, which is a known issue and a new updated motor with improved belt and sprag clutch fitted under warranty, also Spesh say the new motor will have a 4 year warranty from date of purchase of the bike to give me peace of mind
Every time Ive had a motor replaced Ive only been off the bike for one day, the motors were replaced within an hour of arriving at the dealer, along with fitting the new motors they also check the whole bike over including the pivot bolt tightness and adjust anything that needs it and then test ride it to make sure all is OK before handing it back
Cant beat the service Chris Reilly and the team @Berkshire Cycles offer, a great warranty policy and great dealers are key when it comes to e bikes
Had a Bosch Gen4 fail, couldn't be fixed and refunded due to no bikes available at the time of the covid rush last year, went for an e-reign pro, motor, battery, etc has been faultless, but i think i've broken every other bit through crashing, jumping and more crashing, i've read all the water ingress stuff, so i pushed the bike at the start, and that was in the wet months over in FoD and other places, it still running, but as always, there does not appear to be a trend, some fail, some don't, can't see QC being an issue, but something happens where some are just basket cases, and others just bimble on.
Merida with E8000: Torque sensor in motor suddenly died during cold weather after 2.5 years/8500km. Motor replaced under warranty. Only other issue I've had is I snapped the remote cable squashing it in the car.
Levo with Gen1 Brose: Motor still fine after 3 years/6000km. Has broken 2 wiring looms though, they bend too tight when you have to unplug it to charge and it breaks the wires. One of the battery LEDs has failed due to water, still functions fine though.
Are road going ebikes with full guards having failures as well?
Kona Remote Control 2 motors in 2 years. The last time an error message came up I switched it off then back on again and without warning the bike shot across the garage floor and slammed into one of my other bikes. Fair shook me up I don't mind admitting. Replaced by Bosch, I got in touch with them, they were really concerned (they weren't on their own!) Dealer was mortified. After investigating all Bosch could tell me was quite a few errors showed up and I believe water ingress. I don't use a pressure washer just a very gentle almost a dribble hose and obviously don't point it at the motor 🙄
Anecdotally, they appear to much less likely to fail, there are commuter ebikes with 10s of thousands of miles on the original motor.
Well this thread is suitably putting me off owning one now.
Thanks for saving me money!
Think my OH's Gen1 Levo is suffering from intermittent power cutouts that I think is the loom or the connector, and it too has a couple of battery LEDs out but opening the battery up looks simple enough and it'll just be a couple of SMD LEDs to replace.
I was happy to buy used out of warranty tbh, as the industry I work in means that I can have a crack at sorting any issues myself anyway.
I have had issues with over-run. The motor not stopping when I stop pedalling. Specialized Levo. I had the motor replaced. Twice. The 3rd one hasn't done it yet.
I've skim read many threads and from my understanding a lot of it is water ingress, from jet washing, rock strikes damaging the casing, or worn bearings causing too much play.
But there was one guy who dismantled his shimano motor and found a magnetic sensor ring had cracked in two and he got a replacement from someone breaking old motors down for parts.
Someone here also managed to wear out a plastic gear out (after 7500 miles of derestricted riding):
There are facebook groups for various motors. EMTB Forums is also a good source of info.
I went through 3 Gen 2 Bosch DUs in 2500 miles. All failed in the same manner; failed main bearings due to shit design and stupid small chainring forcing grit into the bearings. Pretty much irrelevant now as a point of failure as the DU has been superceded by the Gen 4. None of the failures were ride ending. All bar the first were 7 day turnaround, the first was 4 weeks.
I had an erroneous 504 error on my Gen 4 (tuning detected) it was a known problem that a software update sorted. I'm now at about 1900 miles and have suffered no other issues.
My lockdown riding buddy had a belt failure on his 2019 Levo last weekend. That's the third ride ending failure in 2700ish KM. 9 days and counting on this repair.
Another Levo riding acquaintance has had more motors than I've had hot dinners, the best being an updated motor that lasted 2 rides and 1 mile. Plus several power cables and TCUs. He's lucky; he's an executive with a company car and an office fairly near Berkshire Cycles so all his issues have been fixed in a day.
2018 Kenevo 600km, seized solid. LBS quoted 6 weeks as they were busy so he dropped the motor himself and got them to send it back. Middle of Loockdown 1.
Different 2018 Kenevo, also seized solid, not sure of the KMs on that one, but more than the first. 5 weeks for this one, I think. Pre-Covid.
2017 Levo motor died, 9 weeks to get it sorted. Blamed on Covid by the LBS.
My bosch gen4 is on 1000 miles, my previous gen3 still in use with a mate at 2000 miles. Neither have been jet washed and the gen3 was regularly repacked with waterproof grease. They’re not designed to be jet washed and you see loads of folk doing it.
I briefly had a specialised levo amd that toasted it’s first motor at 150 miles, the second went shortly after and the bike was rejected.
A lot of ebike problems are poor riding technique, changing gear under load and poor washing technique.
@couchy agreed... I see so many people pushing the harder gears and pedalling at low cadences. If only they read the manuals/cared to do any research I think there would be a lot less bikes needing warranty
Looks like water ingress is the cause of most people's woes and that electrical component failure as a result is the show stopper. My next question would be where do we think it's getting in? Is it purely via the crank shaft I wonder? If it comes through the casing then that's a bit rubbish so my guess is via the shaft.
If it's through the shaft seals is there anything that can be done to help prevent this - should grease be applied arouhd the seal externally? Plenty of GT85 after a wash/wet ride (or none - does it make it worse by dissolving the grease inside???)....
Out of interest, what's the problem with this?
It's the main signature I used for spotting an E-bike rider ahead.
So I’ve been looking at an ebike with a Shimano motor which has a 2 year warranty. Does this mean I should be expected to pay £5.5k for the bike and then potentially after 2 years be left with a bill of approx £1,000 to repair and then have it happen again in another years time ?
Has anyone got data on e motorcross bikes? I’ve seen them take more hammer and washing than mtbs (apart from obviously they don’t have the pedalling complication/interaction)
Deffo no gt85, its a solvent and dissolves grease.
I don't think there's anything wrong with low cadences on an ebike, as pointed out its mainly water that causes the issues.
As I understand it (*and I’ve been known to be wrong) but one reason for specialized failures (belt), was razz down hill at v vhigh mph in top gear, and then go into a full power slow steep climb without changing down and overload system. It sounds a bit like lugging a car to me and I’d suspect that’s not good for any ebike.
Short answer, yes, however someone on the EMTB forum has recently had a new Shimano motor under warranty at 2.5 years old so it seems there's some leeway.
Does this affect the repairability issues of ebikes?
New EU rules have been introduced that require manufacturers of electrical goods such as fridges and televisions to make their products repairable for at least 10 years after first coming to market. The rules are designed to enshrine circular economy practices into law and reinforce consumer rights to repair products.
I'm looking at a replacement for my Giant Reign E pro, that suffered from 5 electrical faults and was returned for refund.
I'm not buying a bike with a Shimano motor. If you shoot over to Performance line the only motor they don't touch is the Shimano one. I think he explains in a YT video that this is because of the way the electronics/circuit board are potted and in the way (or something like that). Either way, unless somebody can come up with an out of warranty cost effective repair for these motors I'd avoid them.
Having said that I'm sure somebody will see the lack of an aftermarket repair for the Shimano motors as a business opportunity. Or perhaps Shimano will offer an exchange motor at a reasonable price at some point in the future?
I don’t think there’s anything wrong with low cadences on an ebike, as pointed out its mainly water that causes the issues.
Low cadence + high load = elevated internal temps.
Over the four years of owning them I've seen it go from one or two out on the trails to now seeing the majority on the trails to be emtbs.
Being one that's always up for a chat its quite evident that there are alot now who not been satisfied with the power output are openly bragging they have deristricted them and constantly run them on Turbo
I'm sure that some of this must have an impact on reliability.
I can't see the need to derestrict. IMO people who do are looking for something different to what an ebike is designed to deliver. Riding in Turbo everywhere - WTF? I can only imagine they are blasting about on forest fire roads. The type of singletrack I am interested in would end as hospital at sustained speeds over 15.5mph.
I do most of my riding in Eco, and try to spin at 90 rpm. The Brose motor will tell Garmin via ANT+ what your current cadence is. I WANT my motors to last, and I don't set out to abuse them.
The sprag bearings in the Brose motors are rated to 250nm. The motor puts out 90nm. A 100kg rider (Max according to Specialized is 109kg) by bodyweight alone at 90 deg crank position on 165mm cracks can input 165nm. Already is is possible to exceed the rating of the sprag bearings Then there are the extra forces caused by the suspension action causing chain growth that will manifest itself as torque on the bb axle. The sprag bearings need to cope with 500nm IMO to be safe from damage from normal riding.
I cant see the need either. Most of my riding is in Eco and in the Peak. I'm suprized at the amount that have deristricted. I don't think it's just the area I ride in.
I also believe that by deristricting its got to put extra strain on the motor and the reliability of it.
I use my Levo in turbo loads, I’m basically all or nothing - full power or motor off! Riding up singletrack like that is v intense, so many corners you’d never noticed unpowered.
I suspect that destricting ebikes is a v bad idea for reliability - I’ve heard that one trick is to move the wheel speed sensor to the cranks. With a 15.5mph limited motor you get a burst of power and then you’re on your own and the motor gets to rest.
Derestricting doesn’t make any more power, you can load and stress your motor just as much in a restricted one. All the motor does is spin no matter what speed you are doing it doesn’t make any more power with the limits removed. I agree on a lot of trails 15mph is enough. But some fast trails are a lot more exciting at 25mph I can imagine 👍
I don't see the need to derestrict my own bike either given the type of riding I do. My main goal is exercise so I ride in ECO mostly (85% of the time according to the diagnostic report I got last week). Riding everywhere in Turbo sounds like it will shorten the life of probably most of the components on the bike actually, not just the motor. However Bosch do do a speed version of the CX for countries where the limit isn't 25kph and I wonder what the difference between the two motors is (other than just software). I think if you de-restrict it they will be able to tell and you will have voided the warranty if it does break.
When you think about it e-bikes are fairly new technology so you’re going to get issues. The one common thing with each issue mentioned is the manufacturer, Shimano, Bosch and Brose have repaired or replaced under warranty. Which can only be a good thing. Got an E8000 motor on both e-bikes and had no issues.
I watched a Performanceline repair video and they reckoned it was pedal strikes that did for most of the spray bearings, just too much force going through it so they upgrade them when they do the repair. Seems pedal strikes are a common thing with ebikes. Not sure if its technique or what as they all seem to be putting shorter cranks on all the time. Haven't had this issue with my SL but that could be that the bb height on my analogue bikes are lower so I'm used to watching where I pedal.
This is something I've been thinking about lately too. My mate has Vitus with Shimano kit in he seems to be constantly having to get bits replaced on it due to faults or dead motors or whatever.
It must be frustrating for the owners, but also worrying from an environmental point of view.
I'm interested in the outright numbers. Could a survey be set up?
Those that buy an ebike and ride it all the time in eco why don’t you buy a normal bike ? Eco mode about offsets the extra weight and gives you little against a much lighter normal bike. If it’s about getting fit then ?
Folk seem to have some confusion over how an ebike works, you can still put in 100% human effort same as on a normal bike. If you ride an ebike and only go the same speed as a normal bike then of course they require less effort but if you go much faster than your normal bike you get a similar workout but the reward is much more speed. At my local trail centre I can compete the 6 mile blue route in 34mins on my normal bike, on my ebike it’s 19mins....that’s with me trying 100% so the motor assist gives me the extra speed it doesn’t reduce my effort. It also makes the trail very exciting and let’s a 50+ year old man go round at the pace of the quickest normal bike with a young athlete on it. I see no downside tbh
I do have a normal bike, as I assume most on here do, and also access to a few more. To me its just a different way of riding and in some instances let's me get out when time is short
As I said Eco most of the time. When I ride up the Beast it will be a mixture of Trail and Turbo.
If you shoot over to Performance line the only motor they don’t touch is the Shimano one.
No, they don’t do anything for the Dyname (Rocky Mountain) motor either.
Because I like the torque, I like the way it handles, I like the confidence it gives when exploring, I like the "tech" - loads of reasons really.
And like others have said I ride it mostly but not exclusively in ECO. 🙂
TBH an eBike is a game changer for people like me. 👍
Switch it off and get more exercise...
“Those that buy an ebike and ride it all the time in eco why don’t you buy a normal bike ?”
I often ride with the motor off (inc the odd gentle uphill) and use eco most of the time, I’m 61 and I want to keep active as long as I can. I still use my 2006 orange 5, I’m an natural xc bimbler (enjoying the scenery, etc etc as well as the trails) what the e does is it covers ‘bad legs’, massive headwinds, constant mud, being the wrong side of the hill when you’re knackered, and it lets me go exploring longer and further. It’s changed my riding, with age I tended to route plan, watch the distance and the hills, esp towards the end, now I just go exploring and thoroughly enjoy it
Age has stopped me playing football (2 hamstrings, too slow, so now I do walking football), hockey (to slow, no local vets club, stopped), floorball( ditto hockey), still do tennis but can’t cover the ground or last like the youngsters, mountain biking, well I’m able to exceed what I used to do in my 30s when I started.
Switch it off and get more exercise…
I do, and when I just want to be out, I don't. If that's OK with you! 😉
Also the assistance stops at 15MPH so any time I am going faster than that the motor is off anyway.
pedal strikes will be more on an eeb as you need to keep pedalling over tech to keep teh power going to get you through/over stuff.
you ride stuff (uphill) you genuinely would not touch on a normal bike. i like the 'trials like' aspect of riding the eeb in technical terrain.
i ride my eeb alot harder than my normal bike i recon. and in more horrible conditions. its bound to need more maintenance. the flipside is i get to ride my bike more and in more fun conditions.
My one takes a lot of BB strikes, it's just a weird shape motor mount, bit sketchy on some stuff, but fine on others, i fall off more due to indecision due to thinking a small drop might grind the BB, more than i fall off due to the BB bottoming out!
As for turning the motor off, honestly, 25kg plus bike with completely inefficent tyres and setup means it moves like it's in tar if you turn the motor off on certain stuff, Shorty DD MAXXGrip are not tarmac friendly, i find i can ride way faster on my hardtail with less energy than i can on the ebike in eco on roads and really hardpack stuff, i actually thought the motor had cut out on Saturday when i went from a track to tarmac, but that's on an enduro ebike set up for enduro, last one i had i put light and faster rolling tyres on and it moved not too badly without the motor, bar the extra weight.
“ Shorty DD MAXXGrip are not tarmac friendly”
They’re very much gravity/e-assistance essential tyres! My Levo rolls fairly fast on Hillbilly/Eliminator Gripton Grids but they’re less sticky and tough.
I wouldn't want to ride mine with the motor off. DH casing F&R, MaxxGrip front, ~23kg. Urgh.
I don't ride it much in Eco, unless we're exploring for new trails, or i've had a heavy week of riding & I can't face another big ride but i'm also out with people not on eebs.
Generally i'm a set & forget. EMTB all the time. It's good for 1500/2000m of climbing which does my lunch laps, or weekend blasts when i'm feeling lazy and don’t fancy my normal bike.
As the weather improves, I’m more likely to ride the normal bike as there is more light & less slop, and whilst I love riding my eeb, my Stumpy is better to ride down stuff. Also feels as light as a feather after 3 or 4 rides on the Rail!
Back to the question in hand, I’ve had a couple of electrical failures – plug based & water ingress. A good dry out & the bike has been fine again. That’s about 3500km in 6 months use, in the shitty winter & hosed off a few times a week, on a Bosch Gen 4.
So after reading through the tread I have come to the same conclusion that my Specialized dealer and Specialized customer support have just advised me. You will be out of warranty soon so sell your bike and buy a new one. The Levo Sl cannot cope with uk conditions! So does anyone want a fantastic low power ebike that has had three batteries one motor one TCU one handlebar controller in the last 20 months?
Your specialized/brose is 100% off the shelf part replaceable.
No need to sell.
E bike repairs in Cumbria for example can source any brose part with ease to my knowledge.
My giant however......
Owned it 32 weeks. Broken for 8 of those. Again all parts for the Yamaha can be sourced but giant flash the PCBs with their own software for the syncdrive versions and they won't sell them to third parties. So once it's out of warranty and you get the inevitable Yamaha water ingress then it's bye bye ebike unless you cough up £1300 for a new motor. A non giant Yamaha PCB is about £100-£150.
He doesn't have the brose motor,he has a levo sl that has the mahle motor.
julians
Your specialized/broseHe doesn’t have the brose motor,he has a levo sl that has the mahle motor
Oh okay. Do they fall into the non replaceable, planned obsolescence/one use tech as well then?
There was me thinking all spesh were brose.
Similar on my Kenevo SL, first ride, pedal strike and the crank arm could move in and out 3mm.
Local specalized shop fixed it straight away after contacting customer service.
I don't like turbo mode even on the SL feels disconnected between pedals and moving (I think it's the disconnect between effort and speed) in just wanted less pushing up steep hills.
My Shimano E8000 died after 1600 miles with an E8000 error which is usually the torque sensor and was replaced under warranty,I think part of the problem with emtb motors durability is down to designers trying to make them smaller and lighter which means you end up with smaller bearings and lighter less durable parts,water ingress is just crap design.If I was going to buy another ebike it would have a brose motor because I could at least get it repaired when it broke
How many miles has it covered?
How does a battery 'fail'?
Also, once it's out of original warranty any paid-for replacement motors or batteries should come with a 12 month warranty.
How does a battery ‘fail’?
Either the BMS (Battery Management System) fails, which should be a fairly easy fix with a replacement BMS.
Or a single cell fails, in which case it's not such an easy fix (but still very much doable). Remember that there can be 40+ individual cells in a battery pack and it only takes one bad 'un.
Higher duty cycle.
Or a single cell fails, in which case it’s not such an easy fix
Depending the battery pack construction. What is it like to take apart? Some packs are pretty much destroy to gain access unfortunately.
I've never taken apart a 'high end' battery. The ones I've seen have been cells spot welded using nickel strips, put in shrink wrap, and then put in some kind of solid container.
Not sure if there is any difference if you open up a Specialized or Trek battery pack.
What do you think happens to failed motors? Landfill?
They are refurbished and used for future warranty replacement.
Some of the BMS are bricked if they lose voltage completely making recelling a difficult option.
And if they fail outside of warranty?
I happened to be at Specialized HQ near Zurich and in their workshop was a pallet stacked neatly with boxes of failed motors. I would estimate 200 + all up.
returning broken motors is why you cant just buy a new motor off the shelf for the big brands (bosch etc), you need to go to a dealer for the brand and they will either get you a new motor under warranty ,and return your old broken motor, for refurb and back into the pool it goes , or you pay for a new motor and your old motor goes back for refurb and into the pool.
Yeah it sucks (a little bit) that you cant just order a new motor and fit it yourself like you might do with forks ,and keep hold of the old broken motor as spare parts, and so you end up having to deal with a bike shop and paying to get it fitted, but its not the end of the world, its justa bit more hassle.
Yeah, but how many people who have borked their motor outside warranty buy a new one compared to how many toss it in a skip*?
*or list it on ebay as 'some signs of use'.
Surely it's high time the MTB world collectively go down the not fit for purpose route? No other consumer item would be allowed to have such a high failure rate or a huge corporation like Shimano be allowed to block access to replacements through qualified third parties , it's just commercial protectionism.
2.5 years of reliable riding on my 2020 kenevo so far. Mileage? no idea, i dont track that.
Still has warranty for another year. If it fails out of warranty I will get the motor fixed or buy another motor. Im not about to change the bike near the end of the warranty period as its so bloody good.
I wouldnt buy a bike with a shimano motor though due the the lack of repair options.
So thinking slightly outside the box.
Lots of Emtbs could potentially be "scrapped"* due to motor and battery failures.
It's not a really big task to knock together a mount for a conventional bottom bracket using the motor mounting points (think two plates and a tube).
Will we see a future of converted bikes? Would anyone ride one?
* Not really but some are suggesting uneconomical repair.
Also, once it’s out of original warranty any paid-for replacement motors or batteries should come with a 12 month warranty.
I have even told the warranty even for the new battery ends when the bike is two years old.
Just check the app, it'll tell you.
Two years warranty from date of purchase even though a new battery fitted last week
Warranty replacement or purchase?
oldfart
You'll probably be as surprised as I was to find out but Shimano is the shrimp.
Total sales (corporate) are quotes in Yen but about $2 Bn a year .. less than 1/10th that of Bosch.
This is what really got me... it was totally on me I needed a new battery (left in car park) but £450 and a 2 month wait whilst the bike was a brick... a month after (spending money I borrowed off a mate) the motor died .. I felt totally sick.
If that's a warranty replacement, pretty standard (and not just bikes).
Warranty replacement. That’s when I asked if it would be replaced again under warranty and told my warranty would expire on the 2nd anniversary.
I agree. Asked EMBN if they would do an article!
oldfart
Surely it’s high time the MTB world collectively go down the not fit for purpose route? No other consumer item would be allowed to have such a high failure rate or a huge corporation like Shimano be allowed to block access to replacements through qualified third parties , it’s just commercial protectionism
Do warrantied motors really get refurbished and re-used? I mean does anyone have actual proof that this is the case rather than just thinking it should be?
It worries me that the labour involved in refurbing individual motors could make the process prohibitively expensive compared to simply building a new motor. Take a borked Brose with trashed crank bearings, broken sprag bearing and potentially a worn crank as well plus you'd change the belt too I guess. Is that really going to be worth doing given that we seem to be talking about an awful lot of motors.
Anyone really know? I'm concerned that it's just a wishful fairy tale that people make up so they don't feel so bad about warrantying their umpteenth trashed motor.
How do we know that they're not just going to landfill?
