Easy to clean hydra...
[Closed] Easy to clean hydration bladder?
18 Users
As above.  Don't have space on my bike for more than a 500ml bottle but need more than that. Not too fussed about a particular brand but looking for recommendations on a 1.5 to 2l bladder that is easy to clean eg opens wide, parts come off easily etc
Posted : 14/11/2020 3:32 pm
Evoc/ Source come to mind matey.👍
EDIT: I think Decathlon do a couple too.
Posted : 14/11/2020 3:35 pm
Any Hydrapak ones, I think a few brands use them. They open fully at the top so can be turned inside out.
Posted : 14/11/2020 3:41 pm
Decathlon ones seal along the top, mine is brilliant, easily cleaned.
Posted : 14/11/2020 3:43 pm
Halfords do them too and very easy to clean and very good too.
Posted : 14/11/2020 3:45 pm
Rinse and store in freezer. Not had cleaning issues with any of them doing this.
Posted : 14/11/2020 4:41 pm
Take out of freezer and pour boiling water on it safely.
Posted : 14/11/2020 5:47 pm
Since using freezer method haven’t had any issues but only use water in ours. Much better than trying to clean and dry!
Posted : 14/11/2020 5:55 pm
Hydrapak.
Very easy to clean but best of all they don't really need it, haven't cleaned mine in over a year but it does get used daily so never left to sit more than 1-2 days.
Posted : 14/11/2020 5:59 pm
Hydrapak / Source. Even the wide mouthed Camelbacks are fine.
Freezer storage helps.
Posted : 14/11/2020 6:38 pm
The Osprey ones are the best design IMO
Posted : 14/11/2020 6:41 pm
+1 for freezer storage
Posted : 14/11/2020 6:43 pm
Osprey bladder is difficult to empty fully due to the lip above the filler cap-which has a very stiff retainer loop on it which doesn’t allow the cap to flap open. I have to stuff a couple of pieces of kitchen roll in it to absorb the trapped water.
Posted : 14/11/2020 6:49 pm
Freezer storage after a rinse every use, occasionally leave it overnight filled with water and Milton style tablets, same for those and mouth piece.
Posted : 14/11/2020 6:50 pm
I don't store my Hydrapak bladder in my freezer and it's only used a few times a year, I haven't had any issues with mould or funny tastes and smells.
Posted : 14/11/2020 7:02 pm
Great info thanks. I'll take a look at those
Does anyone use cleaning brushes on the hose? Are they worth it
For folks sticking it in the freezer - does it smell funny after? Sometimes stuff that's been frozen smells a bit weird after
Posted : 14/11/2020 7:19 pm
Haven't noticed mine smelling.
Posted : 14/11/2020 7:21 pm
I just pop a Milton tablet in my 2.5L Osprey every few uses.
only ever used a Camelback with a sort of screw cap thing on the side and an osprey one that has a clamp that slides accross the top of the bladder and it's great. As mentioned above though once its washed out and left to dry for a bit its stuck in the freezer until next time.
Posted : 14/11/2020 8:47 pm
The latest ones don't have a filler cap at all. The full end opens up so you can get right in there to clean them out. The top folds over on itself to close - seems like it won't work but it does. The design is a big step forward IMO.
https://www.ospreyeurope.com/shop/gb_en/hydration-backpacks-reservoirs/reservoirs-spares
Posted : 14/11/2020 8:52 pm
Osprey are Hydrapak. I find their bladders much better than Camelbak IME. Also Decathlon ones are good, similar closure to Osprey/Hydrapak
Posted : 14/11/2020 9:02 pm
Osprey, dakine and evoc I know are hydrapak so have an easy to clean slide top style seal.
I only use water in mine so I just flush it through with fresh water and hang it upside down with the plastic seal inside the flap to hold it open, dries in a few hours.
Posted : 14/11/2020 9:17 pm
Using water without anything in helps.
I use source ones, you can get a towel in and dry them, I take the tube off and spin it round to get the water out. Hang on radiator. Store when totally dry.
Posted : 14/11/2020 9:27 pm
Hydrapak/Osprey/Decathlon all looking good thanks.  Just need to go and press buy on one somewhere
Posted : 14/11/2020 9:54 pm
