Easton ARC (heist) ...
[Closed] Easton ARC (heist) rims - running tubeless
4 Users
Anybody successfully running these rims or the Heist wheel set tubeless?
I've got the ARC 27 rims with stans tape and they don't want to seal.
Pretty poor for a modern rim tbh. That also have a helpful 2mm hole drilled in either side of the rim. Not sure what use that has.
Any secrets to inflating and sealing these folks?
Posted : 24/10/2015 4:27 pm
Mine are running very well tubeless. Didn't touch tape or valves and went straight up with a track pump.
Really helpful vid on Dirt from Rob Scullion at Continental about getting the tyres to seal. Works wonders.
Posted : 24/10/2015 4:46 pm
I've done it now, I think I hadn't tightened the valve tight enough on the rear one. The front went up really easily!
Posted : 24/10/2015 5:49 pm
Yeah no problems here with ARC27 rims.
Posted : 24/10/2015 6:07 pm
 mboy
+1000
Have since used this method many times, on previously stubborn combinations. They now inflate first time, every time, with no real drama!
Posted : 24/10/2015 6:16 pm
