Eagle cassette remo...
[Closed] Eagle cassette removal tool
6 Users
Hi all,
ive just got a new bike with an eagle cassette, I just tried to remove the cassette with a standard cassette tool but it doesn’t seem to fit. Is there a different tool for Eagle cassettes?
cheers
Posted : 03/09/2021 8:38 am
No, standard tool, but they're done up tight. I use one with a 12mm rod in the centre
https://www.amazon.co.uk/Park-Tool-FR-5-2GT-Cassette-Locking/dp/B06ZYFVDJQ/ref=asc_df_B06ZYFVDJQ/?tag=googshopuk-21&linkCode=df0&hvadid=310485825261&hvpos=&hvnetw=g&hvrand=5025714694474035173&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006474&hvtargid=pla-492748648061&psc=1&th=1&psc=1
Remember to grease before re-installing - should have been greased when first fitted
Posted : 03/09/2021 8:40 am
By any chance does you're current tool have quite a big chamfer on the tips? If so, you'll need one thats a bit more squared off as its a much shallower insertion depth. e.g. https://www.amazon.co.uk/Park-Tool-FR-5-2GT-Cassette-Locking/dp/B06ZYFVDJQ/ref=asc_df_B06ZYFVDJQ/?tag=googshopuk-21&linkCode=df0&hvadid=310485825261&hvpos=&hvnetw=g&hvrand=11334492167148359451&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046449&hvtargid=pla-492748648061&psc=1&th=1&psc=1
Posted : 03/09/2021 8:42 am
Have you checked if the hub is one that needs the end cap taken out first?
Posted : 03/09/2021 8:43 am
Hope Hub?
End cap needs removed first. Other hubs probably similar
Posted : 03/09/2021 8:44 am
Thanks all I’ll have another look , the hubs are Propain, I’ll probably need to remove the end cap.
Posted : 03/09/2021 9:10 am
Also get a tool with longest possible recess. The one on the left is hopeless, one on right much better. Basically the splines need to be fully engaged or you risk expensive damage.
[url= https://i.postimg.cc/Njpph412/D1-D629-B4-B355-4-B39-B0-F1-356-D0874291-D.jp g" target="_blank">https://i.postimg.cc/Njpph412/D1-D629-B4-B355-4-B39-B0-F1-356-D0874291-D.jp g"/> [/img][/url]
Posted : 03/09/2021 2:30 pm
