E13 TRS+ (9-46) 11s...
[Closed] E13 TRS+ (9-46) 11spd cassette on sram mech. Anyone running one?
4 Users
I like the idea of the 511% range but have heard they wear quite fast and the shifting isn't great?
Using on an X01 mech.
Posted : 13/02/2018 7:12 pm
Can't comment on wear rate as it's on a bike that only gets used a handful of times a year.....but.....in the first 15 miles the biggest ring bent. Lbs straightened it and it's been fine.
Shifting must be ok as i can't honestly say it is any worse than the original Sram cassette it replaced.
Nice to have the extra range on steep hills.
Posted : 13/02/2018 7:38 pm
I think I've heard of the alloy big ring bending before?
Were you out of the saddle giving it some at the time?
Posted : 13/02/2018 7:41 pm
I honestly can't remember, i don't usually ride out of the saddle climbing, more happier spinning up climbs so i doubt it was that....
I must admit i fitted it myself and i only adjusted the b screw, not the high or low on the mech so it could have been poor set up.
Posted : 13/02/2018 8:15 pm
OK mate,
And the shifting is pretty decent?  What cassette were you using before this one?
Posted : 13/02/2018 8:20 pm
I gave up on mine, it ran perfect for about 3 months then started skipping in the 9t , 10t & 12t under load. Particularly the 12t.
I tried chain tension, b limiter screw but nothing worked. I replaced those 3 cogs and it worked again but only lasted 2 months. I was running a 28t front ring and wonder if a bigger front ring might of helped, though I don’t see how.  The newer ones seem to have changed design a bit and are only 2 pieces not 3 so maybe this is something that’s been sorted. It was a real shame as when it worked the range was great.
Posted : 13/02/2018 8:46 pm
It was a Sram XO1 10-42 cassette and i am running an XX1 rear mech
Posted : 13/02/2018 8:54 pm
Cheers guys....
Tempting but i'd not want to have issues after a few moths!
If one comes up new at a good price I mist take a punt. 😉
Posted : 13/02/2018 10:36 pm
I thought I’d read that Sram mechs (non-eagle) weren’t very happy getting up into the 46 tooth ring.
Posted : 13/02/2018 10:46 pm
Seems to be ok from what Ive read. Plenty seem to be running Sram mechs on the 9-46.
Cheapest I can find for the cassette seems to be £202.  Fair chunk of money!!
Posted : 13/02/2018 11:40 pm
You can get a full Sram GX Eagle group for £340 ish from CRC can’t you?
Posted : 14/02/2018 7:49 am
Just trying to find the review I’d read where Sram mechs were struggling to hit the biggest ring and I’d mixed it up with the sunrace 11-50 cassette. Apparently Sram mechs generally didn’t work with that but Shimano ones that claimed up to a 46 tooth worked ok with it.
Posted : 14/02/2018 9:41 am
Ah, I see mate. So sram on a 50 tooth is an issue?
Posted : 14/02/2018 6:06 pm
