E13 crank spacing -...
[Closed] E13 crank spacing - help
2 Users
New bike (used).
Stripping various bits that aren't quite right to sort them out.
It's a Dartmoor Hornet. Gorgeous. For my teenager. He will soon be flying.
The cranks were badly setup, not clamped up enough, spacers all wrong.
It's a E13 TRS (I think) and I've never used E13 stuff before.
So I've worked out I need a new tool to turn the cups. Got round that today because cups were not actually tight. ! .
But when I google spacer selection it tells me to use for
73mm shell (by my measuring) =
1x2.5mm drive side
No Nondrive side
No spindle spacer
When I put this together it results in massive offset. Drive side arm 1mm from chainstays, nd arm miles away. Just wrong.
Any help?
Posted : 11/09/2016 7:18 pm
There abound be an adjustable collar on the nds arm to take out the play / pre-load bearings, is it in place?
Posted : 11/09/2016 9:24 pm
No.
Ive been seeing that adjuster collar adaptor thing on my google findings.
The crank arms just say 'e-thirteen', theres no mention of 'trs' anywhere.
have they always had that adaptor? Maybe its an older version.
Their website aint much help...
Posted : 11/09/2016 9:52 pm
D side is 3mm gap away from cup
ND side is flush
Do i just choose my own spacer arrangement to get it right?
Or is this gap where an adaptor should be?!
Posted : 12/09/2016 7:21 am
