e bike brake cutoff
[Closed] e bike brake cutoff
6 Users
A friends daughter has this Blix Soleil ebike.
The brakes are rubbish and I don't think the motor cutoff works so the bike tries to power through the brakes.
I have some MT200 hydraulics but hadn't realised that on the existing cable levers there's a cutoff switch.
5 pin connector that screws together.
Aside from ideally a hydraulic brakeset with a cutoff switch in the lever, what do I need to make these MT200's work with the control system?
Posted : 13/03/2022 1:36 am
edit, sorry , round red 2 pin push together connecter from brake
Posted : 13/03/2022 1:52 am
I suspect it’s the motor still operating when she’s braking that makes the brakes seem rubbish.
Also I notice it has a throttle so is the throttle not being closed properly when stopping?
My suggestion is to fix the fault rather than change the brakes, the cutoff seems to be a decent  safety feature (when working obv)and I wouldn’t be inclined to bodge or bypass it onto a new lever. I would get the bike to a dealer to fix if it’s nothing obvious like a damaged cable.
Posted : 13/03/2022 6:31 am
You can get switches that work with hydro brakes
ie
https://besbike.co.uk/product/hydraulic-magnetic-brake-cut-off-sensors-for-bafang/
Posted : 13/03/2022 8:28 am
I've never understood the need for these switches. Surely the motor cuts out when you stop pedalling and nobody brakes whilst still pedalling?
Posted : 13/03/2022 9:17 am
Cadence sensors take a second or two to cut out sometimes and bikes with a throttle obviously you can have the throttle open with the brakes on hence the reason for the brake cutouts.  Not needed on torque sensor bikes
Posted : 13/03/2022 9:21 am
Ah, thanks, makes sense 🙂
Posted : 13/03/2022 9:30 am
Problem you might have is finding a dealer or a bike shop that'll fix it. Since it's got a throttle it's not UK legal so a lot of shops won't touch them.
Posted : 13/03/2022 9:34 am
Anyone ever ridden a motorcycle with an engine cut-off in the brake levers?
Posted : 13/03/2022 9:40 am
no but overrun slipper clutches are a thing 🙂
Posted : 13/03/2022 10:06 am
