2013 Sektor RL Solo air forks.
since they are 2013 RLs, they have just an 'open port' rebound assembly and a standard MoCo damper, as i understand it.
i'd like to upgrade the rebound assembly first, to dual flow, as seems to be consensus.
Is it just a standard one from a set or Revelations?
ie this one?:
http://www.ukbikestore.co.uk/product/353/r5545030/rockshox-rebound-damper--seal-head-assy-revelation-10-13.html
AND, if i wanted to upgrade the compression damper to DNA, but stick with RL adjustments, is it just this one, from Revelations too?:
anybody done one or both of these to sektors? is the DNA upgrade worthwhile?
guess i'll do rebound first and see if i'm happy.
I'd speak to Simon (LoCo) for advice.
so would i, but it's the weekend and i'm impatient!
I got the dual flow rebound assembly from loco a few years ago and it transformed the sektors. I still use them on my slackline and they have brilliant coil plushness with good dampening, never bothered swapping out the compression though!
Leftfield option- there's lots of old revs out there now and you need to neglect them pretty damn hard to kill the dampers. I needed a bit for my ancient blackbox rev teams so I got another set with stanchion wear for peanuts, passed on bits I didn't want to other folks...
Well worth the upgrade imo, the compression dampers have got better too but it was always the rebound that held the old motion control back.
smart. i'll give loco a call on monday.
aye, i'd prefer the dual position coils than solo airs turns out,
jamiesilo - Member
As its a Bank Holiday I'd leave it till Tuesday
righto, no idea, in france : )
just a bump to see if anyone can confirm actual parts
anyone?
(still impatient)
I bought RS part no.: 11.4015.397.020 for the same thing. Listed as Black Box Moco rebound damper and seal head, or something. Not sure if it's available anymore though as they updated to the 'rapid recovery' stuff (it's not available anymore where I bought mine, hence no link).
thanks warpcow : )
can find that too at mountainbikes . net , so i guess i can choose older blackbox (is dual flow), or newer simply called dual flow.
apparently it's better and seemingly cheaper!
