It's on a Trek Fuel EX9 - it has a pawl freehub (not star ratchet)
Do I need to remove the ratchet ring to get the drive side bearing out? doesn't seem to want to shift with the ring in place. If so, presumably there is a special tool?
thanks
DT Swiss tool to removal the 3 pawl ratchet ring is
HXTXXX00N5266S
About £60, I think you can get copies on ebay.
I've done E1700 and E1900 bearing changes (both pawl) without any special tools
As above 370 3 pawl hub zero special tools.
Couple of sockets, few blocks of wood, rubber mallet and a small vice. Punch for getting out the bearings.
No need to remove the ring
Hear hub with boiling water
Freeze bearings
Press bearing in
Tried doing that to my Roval rear wheel today which I think has DT Swiss 360 internals and I can't see how you'd do it without the tool. I've just ordered one from ebay for £18 so we'll see how it goes when it arrives.
Do you have a press or a drift? Press makes it super easy
