Dt Swiss Freehub Ex...
Dt Swiss Freehub Experts?
6 Users
3 Reactions
Hi,
I need to get a Shimano HG Ratchet freehub for my 148/12mm boost DT Swiss 350 hub (currently have XD version). I think the aluminium version is HWYABX00S3745S - but there is also a Hybrid steel version which might be better if it fits as its for a Pinion gearbox bike - all the load will go through the same area of the freehub.
I cant tell if the Hybrid and Aluminium freehubs are interchangeable - any idea if they are or where I can find out? The DT Swiss webpage is a bit crap for this.
Cheers.
Posted : 08/12/2025 6:09 pm
 PJay
Can't help with your query, but the folk at Madison who handle DT Swiss service in the UK are really helpful.
dtswissservice@madison.co.uk
Posted : 08/12/2025 6:21 pm
blaggers reacted
 mboy
Yes the end caps are interchangeable... Or at least I have managed to interchange them myself on a 350 Hybrid hub, going between a steel hybrid freehub body and a conventional aluminium one...
Posted : 08/12/2025 7:09 pm
Yes the steel one will work no problem. Just get the right pawl/ratchet mechanism
Posted : 08/12/2025 7:10 pm
blaggers reacted
All the Pinion sprockets I’ve seen have a wide bit that transfers power to the free hub so you don’t need a steel one.
Posted : 08/12/2025 8:22 pm
blaggers reacted
For a 350, unles you have one of the new spangly DEG versions you will need a standard Ratchet freehub.
https://www.freewheel.co.uk/dt-swiss-ratchet-freehub-conversion-kit-with-steel-bearings-varconkitratch
Colour: Hybrid Grey Steel
Shimano MTB
12 mm Axle
Posted : 08/12/2025 8:24 pm
Thanks all - have found a Hybrid version on ebay for £50 so ordered that. Cheers.
Posted : 08/12/2025 9:15 pm
