Hi all,
Time to mine the collective parts hunting power of STW...
I have a brand new DT Swiss E1900 wheelset which has the 350 hubs at their centre. They came on my Mondraker Dune RR and as such have the XD freehub on a 142 x 12 axle.
I sold off the SRAM groupset as new when i got it and put my XTR on with hope wheels. I can't be bothered with the expense of a Sram cassette to build them up as a spare set of wheels, so thought about swapping out the SRAM XD freehub for a shimano one.
Can i find one anywhere? not a hope in hells chance. Dead easy to find the SRAM version i already have, but not the other way around.
Does anyone know if Shimano freehubs with 142 x 12 freehubs are available for the 350 hubs? if so, where?
Cheers All
One here, but doesn't mention spacing/width? Not mine BTW
unless Mondraker have had some special E1900s made, the freehub wont be a 350 (because the hubs aren't 350s). You need the standard pawl style - best to get your LBS to call Madison to get the right part. You'll also [i]probably[/i] need new axle adaptors too. I don't think the F/Body comes with them.
Madison currently only deal with the aftermarket hubs which all come with Rachet freewheels, if you need a pawl freehub then you should talk to TF tuned who handle spares and servicing for the complete wheels.
Cheers all, Didn't realise TF did the wheelset support, so have contacted them
The rear hub on the E1900 is not a 350 it's a 360 or 3P hubs.
It's the ''new'' 3 pwl hub system.
Reference you need for a shimano freehub kit in 142/12 mm is : hwyabm00s6150s which include both freehub and encaps
