dt swiss 350 freehu...
[Closed] dt swiss 350 freehub body
10 Users
Mine is badly scored from the cassette. Struggling to find a replacement ?!?! Plus how do I stop this on a new one?!?! Do the make a steel option similar to Hope???
Posted : 02/02/2015 11:15 pm
look on ebay - same freehub as on 240s.
9/10 speed £45
11 - more
no steel
Posted : 03/02/2015 12:02 am
take your file out and knock off the burrs. Should survive a little longer.
Posted : 03/02/2015 12:22 am
^^ this
Posted : 03/02/2015 7:42 am
I can do you a new one for £35 if you need?
Regards
g
Posted : 03/02/2015 12:34 pm
I have one on ebay.... http://www.ebay.co.uk/itm/271760016428?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
I'm sure a deal can be had!
Iain
Posted : 03/02/2015 12:50 pm
It runs the same freehub as a 240 which will help you find one online.
Posted : 03/02/2015 1:49 pm
Iain's one has been drilled and machined out more aggressively than the standard ones, more like the freehub body on a 180 Carbon hub, but without the ceramic bearings. I'd buy that!
Posted : 03/02/2015 2:07 pm
Thanks njee20!
Posted : 04/02/2015 7:26 am
I jave a s/h one with good bearings you can have for 20 squids posted.
Posted : 04/02/2015 8:25 am
Iain65 all done on ebay - cheers
Posted : 04/02/2015 9:05 am
Lee, didn't realise you had bought it - thanks. Posted on Thursday first class.
Iain.
Posted : 06/02/2015 11:09 pm
Simple problem is the freehub shell is ali alloy and cassette likely has a steel spider, so harder metal eats into softer.
A more expensive cassette with ali spider will help, though depends which alloy is harder.
I believe there may be a steel freehub option, but yet to look into that. When I got my 350 there wasn't the option.
Or just replace the freehub when it's too far gone.
Posted : 06/02/2015 11:59 pm
Yup , I've had the same problem . I've been told XTR cassettes are kinder on ali freehubs , so will find out soon.
Posted : 07/02/2015 10:01 am
