DT 240 freehub- Hel...
[Closed] DT 240 freehub- Help!
4 Users
I need to replace a DT freehub on a 240S hub, and this is what I've got...
But the old one looked like this...
The main difference being the new one has a cover over the bearing, and this fouls the end cap (pictured in the second, er, picture).
Have I got the wrong part? (the part number on the pack is correct). Can I get this cover off? I'm a bit stuck!
Posted : 28/02/2012 10:31 pm
 nikk
You need a new cover (can't remember the proper term). I had the same thing happen servicing DT Swiss Onyx, seems they have changed the freehub design over the years.
Posted : 28/02/2012 11:06 pm
A new end cap? (the small part in the second pic)
Top pic is the new part, I've seen loads of these listed as supplied with end caps- maybe I'm missing a new cap that should be in the pack.
Posted : 29/02/2012 6:16 am
Found this aswell (on onyx also). Just take the rubber bearing shield off!Or buy a new end cap (without the tophat bit).
Posted : 29/02/2012 7:59 am
Yes they changed the end cap design, if you've got the integrated dust cover you can pick the one of the newer design freehub body.
Posted : 29/02/2012 9:50 am
