Dropping the big ri...
[Closed] Dropping the big ring.
8 Users
After a catalogue of transmission failures at the weekend, i am going to drop the big ring to simplify the gearing. Is my thinking right in terms of what i need to do, or am i missing something?
1) Replace 44t ring with 36T bash.
2) Re adjust front mech so that it doesn't go further out than the
middle ring.
3) Shorten chain
Is it that simple or am i missing some key steps?
Is a chain guide required?
Rich
Posted : 04/02/2013 9:55 am
It's that simple. Only other thing is a lower roller. All depends whatnand how you ride.
Posted : 04/02/2013 9:56 am
You don't have to shorten chain unless you're changing the sprocket sizes on the remaining rings (AFAIK)
Posted : 04/02/2013 9:59 am
Shortening the chain isn't necessary - but it increases the chain tension on the middle/small rings which is good as it'll reduce noise/chatter and the chance of the chain dropping off the ring.
I guess it also saves the weight of a few chain links 😉
Posted : 04/02/2013 10:02 am
you dont 'have' to shorten the chain but you will find doing so increases chain tension and stops it dropping off nearly as much
(was the main reason i went double)
also, get a larger bash but dont feel you have to put a bigger middle ring on than 32 just yet, im running 32/22 * 9 and its actually fine (long road sections excluded)
and yeah no need for a roller/ chain device unless you find you are still loseing the chain after shortening it
All depends on location and rider cadence etc.
Posted : 04/02/2013 10:04 am
Mike, completely agree
Im just saying its worth trying before you go out and buy a 34/36
Posted : 04/02/2013 10:06 am
Changing the middle ring is only worth doing if you use the big ring a lot at the moment. If you don't use the big ring then the middle is sufficient for you
Posted : 04/02/2013 10:08 am
All the above plus do you need the bash?
I've ended up with 22/36 and a Bionicon v2.
I only needed the chain device because my bikes front mech is direct mount so won't drop low enough to perform chain guide duties.
Posted : 04/02/2013 10:17 am
The only thing I would add is to get a shorter cage rear mech next time around too. I reckon it is worth shortening the chain though for the reasons above.
Posted : 04/02/2013 10:35 am
