Dropper seat with o...
[Closed] Dropper seat with offset
14 Users
Thinking about getting one of these and the RS Reverb looks good but no offset. Are there any good ones about with 125mm travel and offset?
Posted : 23/08/2012 9:24 am
Only ones I know of with a 125mm drop are the Specialized Command Post and the KS/Pure i900. Well, there's also the RASE Black Mamba but no-one seems to use that.
Really wish the KS LEV had a setback head but apparently they've no plans to do one.
Posted : 23/08/2012 9:47 am
Joplin 4 - not quite as much drop as you want but has layback.
KS do a few with offset as well. Not sure about the LEV but the older ones with the remote cable going into the top of the post have layback.
Giant Contact switch has layback and currently 15% off at cycle store
[url= http://www.cyclestore.co.uk/productDetails.asp?productID=53837 ][/url]
Only 100mm drop though and I'm not sure if it's any good as there are very few report from the wild.
Cheers,
Andy
Posted : 23/08/2012 9:53 am
gravity dropper i beam version, more layback than you could shake a stick at
Posted : 23/08/2012 9:55 am
 IA
Specialized command blacklite, ace bit of kit (have one for the same reasons)
Posted : 23/08/2012 10:03 am
Thanks will have a look. Just wish these things were cheaper!
Posted : 23/08/2012 10:29 am
We are running Specialized Command posts on our bikes 125mm on Abigales, Kevins and mine and 100mm on Katies as she has a small frame and the 125mm wont lower enough for her. We didnt know at the time and bought a 125mm for her. I now have a new 125mm still in the box if you are interested in buying one.
We have been useing them for 18 months including 2 weeks in the Alps and have had no issues with them
Posted : 23/08/2012 10:47 am
Tracey - What size and how much?
Posted : 23/08/2012 10:51 am
Its a 30.9 with 125mm of drop. It has 3 positions fully up, fully down and 25cm down. Will have to measure over all length tonight
Its like this one
Posted : 23/08/2012 10:58 am
Need a 31.6 so don't worry Tracey. Thanks for the offer though.
Posted : 23/08/2012 11:00 am
Whereas my Trance has a 30.9 seatpost. Not sure I've got room for 125mm drop, but if it would fit and the price is right I could be interested.
Cheers,
Andy
Posted : 23/08/2012 11:17 am
Andy
Will get some measurements tonight
Posted : 23/08/2012 11:20 am
Spesh blacklite. I needed a 31.6 but they only do them in the states..got a 30.9 and shimmed it. Not had a problem yet, great post.
Posted : 23/08/2012 11:26 am
Andy
Thanks. I guess what I need to know is the minimum distance that you need to have between saddle rails and the top of the seat tube clamp to fit this in. Not sure how easy that is to measure and can't seem to find a link to any site that gives you the info though.
Cheers,
Andy
Posted : 23/08/2012 11:38 am
My KS i900Rs (now called Dropzones I believe) have 125mm of travel and layback. They seem to work pretty well.
Posted : 23/08/2012 11:50 am
I run a 125mm reverb on the older style (kinked seatpost) 2010 trance just fine (380mm total length)
Posted : 23/08/2012 11:56 am
Tracey,
I think you listed the measurements in a previous thread:
http://singletrackmag.com/forum/topic/dropper-post-questions
If I understand that correctly I'd need 195mm from top of seat collar to the saddle rails in order to fit the 125mm version (and 170mm for the 100mm version). I'll measure my bike tonight.
Cheers,
Andy
Posted : 23/08/2012 12:01 pm
If Andy 'roverpig' doesn't want it, I may also be interested if the price is right.
My email address is in my profile - drop me a line if it's still available after Andy's measured his bike.
Cheers,
Higs
Posted : 23/08/2012 2:07 pm
Will do
Posted : 23/08/2012 2:09 pm
Just a note: I ran my reverb with the saddle all the way back on the rails for various reasons. When it was new it bound quite badly as effectively your bending the post rather than compressing it when trying to lower it. A mix of the post bedding in and sliding the saddle to a less extream position's cured it.
I presume that's why there are very few properly laid back* dropper posts.
*the Reverbs lightly laid back, the clamp looks about 10mm behind the shaft?
Posted : 23/08/2012 2:32 pm
Reverb looks pretty straight to me.
Posted : 23/08/2012 3:00 pm
25cm down
Do you mean 25mm / 2.5cm rather than 25cm?
Posted : 23/08/2012 4:33 pm
Yes
Posted : 23/08/2012 6:56 pm
Email sent.
Andy
Posted : 23/08/2012 10:51 pm
Had my first proper ride with the Specialized command post yesterday. Thanks Tracey, it works a treat. I'm the sort of lazy sod who can rarely (if ever) be bothered to get off just to drop the saddle, so I'd mostly been riding with one height. I had tried dropping it when I knew there was a long descent, which made me realize how much easier it is to move your weight about with the seat out of the way. But most of the natural trails that I ride have lots of short downhill sections and I just couldn't be bothered to drop the saddle and raise it again. But with the dropper that's just not an issue and I was knocking it down for most downhill sections, which really helped with the flow.
Cheers,
Andy
Posted : 02/09/2012 10:50 am
I've had one since February and it's still working fine. It's developed a bit more rotational play from when it was new but still not enough to be noticeable when riding. Giant's reputation for customer service is good too.
Posted : 02/09/2012 12:03 pm
Glad you liked it
Posted : 02/09/2012 3:19 pm
Thanks, sure did. I was a bit of a dropper sceptic to be honest. I felt OK descending with the seat up, until I tried the alternative.
Cheers,
Andy
Posted : 02/09/2012 10:02 pm
