Dropper posts - con...
[Closed] Dropper posts - convince me.
65 Users
Cheeky bugger.  I'm 10st 10lb.  I probably need a bit more lard to make most suspension work 'as intended'.  Especially noticeable on my motorbike.
Posted : 12/04/2018 10:51 am
^ OP. molgrips meant body weight lower as in lower on the bike, CoG, not lighter.
I like the middle way.  On my old HT, and now moved to my Fat, I have an underseat lever KS.  Yes, you have to think a bit in advance, so I use it as an on the fly QR sorta thing.   I like the Raiser analogy too: I usually ride most things 1 to 2" down from full climbing extension.
Advantages:  no annoying cable or remote to route or need to bleed, can easily swap with solid post & saddle for bikepacking or between bikes, cost nowt secondhand, is only 350g over my Thomson fixed post.
I killed the Reverb on the FS on a very wet Wales trip, so I'm going to remove it and try this.  Reckon it'll be fine.
(I've a rigid SS too with fixed post and it's staying that way; as I ride less gnarr on it and it's all part of the KISS ethos of that bike)
Posted : 12/04/2018 12:19 pm
I can’t live without one, but I used to spend a lot of time dicking around changing my saddle height, even back in the day. I hate riding anything fun (jumps, drops, DH trails) with my saddle up. Always have done.
Its one thing that genuinely makes riding better for me
Yes, that's what I meant.
In the lakes there are lots of long bumpy descents - those are rough without being technical, so whilst I'd still drop the saddle, it's less of an issue.  What a lower saddle allows you to do is move around a lot more, and get your weight in the right place for manouevring the bike - body English, as mentioned above.  Not required on a long stony track, but essential on singletrack if you want to go fast.
Do French MTBers talk about 'body French' I wonder?
Posted : 12/04/2018 12:26 pm
uppy downy seatpost,that’s their prerogative,each to their own,same goes for suspension,to me it;s all high maintenance/high cost BS. ….IMO.
What do you mean when you say suspension etc is bullshit?
Do you mean it's benefits are a lie and a fabrication by the industry to sell more bikes? Or do you mean it's just not a necessity to ride your bike and have fun?
If it's the former then I fear for your sanity, if it's the latter then I might be inclined to agree with you, although it does open up many more riding possibilities that could be considered even more funerer!
Posted : 12/04/2018 1:40 pm
Cheeky bugger.  I’m 10st 10lb.  I probably need a bit more lard to make most suspension work ‘as intended’.  Especially noticeable on my motorbike.
I think this misunderstanding is quite telling. As has been pointed out the meaning was getting weight lower rather than lighter. If the meaning of lowering weight down into the bike went over your head them you very well might not see the advantage of a dropper post.
Posted : 12/04/2018 2:03 pm
^^ A common or garden misunderstanding of a sentence on a forum is not the same thing as being undecided on the merits of droppers. 😃
Ones a mistake, ones an opinion....  Bit harsh to join dots between the two?
Posted : 12/04/2018 2:15 pm
I used to be in the don't bother camp with a dropper post. Then I bought a bike with a dropper and now I wouldnt be without one. I use it every ride and its 100% improved my riding.
Posted : 12/04/2018 2:21 pm
Maybe. On the other hand to someone who understands the benefits of getting low on the bike the meaning would have been obvious. Or maybe they are just a bit touchy about their weight 😉
Posted : 12/04/2018 2:22 pm
There are benefits to having a petrol engine on a bike but not everyone wants to ride a motorbike... 😉
Anyway, just thought it a smidgen harsh to make a link between the two points you raised is all. 🙂
Posted : 12/04/2018 2:42 pm
"I think this misunderstanding is quite telling. As has been pointed out the meaning was getting weight lower rather than lighter. If the meaning of lowering weight down into the bike went over your head them you very well might not see the advantage of a dropper post."
You can still get your weight lower without lowering the seatpost. I do understand the principle of moving around on the bike, I've been riding MTB for 27 years and motorbikes for 47. Anyway, yes, I misunderstood the post about weight.
However, as I said, I'm going to give it a try as soon as I get round to refitting it.  I'm very open to being wrong and discovering that getting my weight as low as possible will make me a riding god. We'll see .....
Posted : 12/04/2018 2:43 pm
I might understand weight distribution, but obviously not how to quote from a previous post ....
Posted : 12/04/2018 2:46 pm
Last ride at Swinley, used hardtail, didn't miss dropper. (Though my post was gradually lowering itself, so I did wish I didn't have a busted QR clamp!)
Other rides at Swinley I follow my son over jumps and the post lower means it's sooo much easier to jump the bike. And I don't even jump high. If you jump or do drops, not having a saddle in the way just make sense.
The boy laughed at me at BPW the other day cos I didn't lower my saddle on one of the blues. It was quite pedally!
Other runs I did drop it.
I mean, some people don't feel the need for dropper posts, I just don't feel the need to have other people make decisions for me!! 😆
Posted : 12/04/2018 2:47 pm
If I brake hard my long travel bike dives.  To mitigate this, I put my weight back and keep it low.  With a lower saddle, I can get my weight back and much lower.
Posted : 12/04/2018 2:49 pm
I don't know why this is still a debate
Droppers are just better - end of!
The bike industry is routinely guilty of selling us things we don't need / stuff we don't want / stuff we never new we wanted etc
Droppers are not one of these things...We didn't suddenly start dropping seat posts because droppers became a thing. Its pretty obvious that if you want to enjoy a descent then you need the seatpost out of the way. I learned that after about half an our down the local woods as a child - now its just easier as I have a button for it. I mean that is why we ride bikes isn't it? For the decants!  Even if you prefer climbing I don't understand why you would make the decants harder, more uncomfortable and more treacherous on purpose. Makes no sense?
The only reason I can come up with is that perhaps for some people, bending over double and having something stiff pressing firmly against your arse is somehow pleasurable? I'm not even joking - I literally cannot think of any other reason.
Posted : 12/04/2018 3:36 pm
I mean that is why we ride bikes isn’t it? For the decants!
No.
There are downsides:
1) Weight
2) Reliability and servicing
3) Cost
4) This is controversial, but it's another thing to do and think about.  When I use one, I am thinking 'is it time to drop?  Yes/No' then reaching for the lever.  It's another process, however small.
My saddle isn't pressed against my arse when I'm descending without a dropper.  It's on my stomach.
I don't use one on all my bikes and I don't think I will.  But for many bikes, it's essential to use the bike as it was designed.
Posted : 12/04/2018 4:07 pm
My saddle isn’t pressed against my arse when I’m descending without a dropper.  It’s on my stomach.
I think that's even more contentious than the dropper debate!
Posted : 12/04/2018 5:47 pm
After mine lunched itself (again) one mile into a ride today I am starting to look favourably at the advantages of a normal post and a quick release...
Posted : 12/04/2018 6:07 pm
TBH, sounds to me like OP is going with peer pressure if all his mates have eschewed droppers.  Also guessing he hangs off the back when the saddle is down, this lightening the front if descending with saddle dropped is sketchy and worrying
I can see why on the fly adjustment of saddle height is less attractive if you only ever ride with people who stop and faff at the top and bottom of everything.
I guess droppers aren’t something that it’s impossible to ride a bike without, but I’d want one on any mtb of mine.
Posted : 12/04/2018 6:49 pm
I didn't spec one on my FS when I bought it (2011) & they were just getting 'fashionable'. After much faffing aboutery I succumbed & got one, a Reverb.
It's very handy but I wouldn't say it's changed my life. I don't do trail centres & the natural bits I ride where I need the saddle down are less than when I need it up.
I'll keep it though.
Posted : 12/04/2018 8:09 pm
Page 2 / 2
