I have a Ghost Kato FS 5 and looking to add dropper post but not sure what best one for bike is
Reverb imo
"Best"?
Take your pick of the many dropper posts available.
I've had no problems with Rock shox Reverb, others have.
Depends on your budget and if your frame accepts a "stealth" dropper post with internal cable/hose routing?
Welcome to the forum op! 🙂
A said, depends on budget and drop required etc etc.
That said there are some good budget posts around these days, around the £150 mark, Brand X etc. Many under £100 these days too... but [u]some[/u] that cheap can be a bit problematic, not all though.
EDIT: Brand X ones start from nearer £120 actually.
Doesn’t have internal routing...I should’ve added it has 2x11 mech so that’s mainly why I was looking for something that would fit since most droppers have bottom mount lever
Ok, I'll start the ball rolling with this model of Brand X.
Not internal routed and the lever style should be ok for 2x set up... or use a third party one. Being cable actuated there are quite a few compatible levers available.
Doesn't have the cable coming down from the top of the post either so much neater. Other brands will do similar but Brand X posts are very good for the money. Good for any money actually, as good as the big brand names in my opinion. I have the internal routed one.
