Dropped posts
[Closed] Dropped posts
11 Users
What cheaper options are people using at the moment which seem reliable? I'm looking for a 31.6 internal routed but can't stomach £300 odd for a bike I use infrequently. Cheers.
Posted : 30/09/2016 4:59 pm
I've got a KS eten because I'm poor. It takes a bit of time to set up right but is otherwise decent. Original cable is a bit crap though but will do for a few months.
Posted : 30/09/2016 5:30 pm
Your the second person who has recommended one of those. It's creeping up my list.
Posted : 30/09/2016 5:46 pm
 m0rk
I've got a KS e-ten as well (came on a bike), works nicely & even the thumb lever is slick after a lube.
Also I have a Reverb on another bike, which is nice. But no better
Posted : 30/09/2016 6:29 pm
Another vote for KS here
Posted : 30/09/2016 6:50 pm
Looks like an eten then!
Posted : 30/09/2016 7:23 pm
Yep, KS E10 in my Hardtail.. It works
Posted : 30/09/2016 7:30 pm
/blatant hijack...
If you are interested I have an internally routed 31.6 KS post (I think a KS e30 integra) that I bought on here in error - it was a new bike pull. E30's are OE ETen's I think.
I was planning a build it would have been useful on but I've ended up external. I'm going to be selling at some point, happy to talk about it on email if you want 🙂
Posted : 30/09/2016 9:15 pm
RSP Plummet gets good reviews, can pick them up for £75 ish
Posted : 30/09/2016 9:54 pm
New bontrager ones are £240
Posted : 01/10/2016 6:37 am
My LBS are doing a Giant one for about £175 fitted.
Tempted when I have the pennies.
Posted : 01/10/2016 8:14 am
double trouble
KS eten. Great posts. Very reliable (once setup properly).
My only complaints are:
1) fiddly to setup. But once setup (perfect cable length) they work great.
2) a bit heavy.
3) trigger mechNism (under the saddle) is not well shielded from mud/grit etc. and needs a clean after riding to make sure no mud is there which can affect operation. I ended up doing a modification that increased the tension on the trigger spring which helped the lever return stronger, which helped when it was clogged up with mud. (Note: this only affects the lever return. Not the seat post return rate).
Posted : 01/10/2016 10:19 am
The Brand X dropper is due in stock in about 2 weeks . It has been well reviewed in 2 tests that I have read . Cost is £140 but they are doing some kind of offer if you buy early and you can get one for £100 .
Posted : 01/10/2016 11:21 am
