Drivetrain binding,...
[Closed] Drivetrain binding, why?
6 Users
Just fitted XT M8100 drivetrain, all new, Hope pro 4 free hub.
When spinning the rr wheel backwards the cranks are spinning backwards and there is a rumbling when pedalling
Posted : 16/07/2020 9:32 pm
Someone just had similar problems with SLX on his Trek Rail. Is the silver drive-side spacer the correct one for the Microspline freehub?
His was new too, but I think they had been converted from new, but the wrong spacer was fitted.
Posted : 16/07/2020 9:56 pm
What drive side spacer?
The one fitted to the crankset?
Posted : 16/07/2020 10:22 pm
 LAT
If you spin a wheel backwards it won’t freewheel, so the cranks will also spin.
dont know what would cause a rumbling noise on 12 speed, but I’ve had a similar sound coming from the chainring with new kmc chains on a variety of aftermarket 11 speed rings.
Posted : 16/07/2020 10:54 pm
Rumbling could be b-screw?
Posted : 16/07/2020 11:29 pm
Yep it’s normal for cranks to spin when pedalling backwards as the hub can’t freewheel.
It’s more a problem if the cranks are spinning when your freewheeling.
Posted : 17/07/2020 12:07 am
Have you threaded the chain correctly through the rear derailleur? i.e. so the chain isn't rubbing on the dividing tab between the inner and outer plates.
Posted : 17/07/2020 9:19 am
Thanks all, i had described it wrong, cranks were spinning when freewheeling which is obviously bad.
The spacer hadn't come out when removing the hyper glide driver, so it had 2 in there when the microspline driver was fitted, now sorted.
Posted : 21/07/2020 2:55 pm
