I'm after a bladder that has a really high flow rate. Any ideas?
I've mistyped, this will be about hair now.
s****s, you'll need to comb through any replies for helpful information.
My hydrapack has a much lower flow rate than the Source widepac that it replaced (tear in the mouth piece).
The Osprey ones are good. If you do need a really high flow rate a water bottle may be better.
The flow from my Osprey is far better than my camelbak.
If that's not good enough you could try a [url= http://www.geigerrig.com/hydration-packs.html ]Geigerrig[/url] bladder.
That would be too much for me toupee!!! 😀
Ospray bite valve has always been higher flow than any other brand that I have used.
currently using
a 3L platypus which has a very low flow rate.
a 3l hydropack bladder (has a good flow rate and easy to clean, but stains easily)
a 2l platypus hoser which has good flow rate
a 2l camleback which has the highest flow rate of the lot. however it doesnt have a flow device on it. fitting on of those and it ends up being the same as the others.
