drawing up a frame
[Closed] drawing up a frame
9 Users
Debating a custom full sus.
but thinking about it, I could do with some help.
Idea so far:
seat tube = 76 D
CS = 430MM
STL = 500MM
Head angle= 64 D
ETT = 670MM
Reach = 520mm
stack = 615mm ish
Would any one be able to work out the wheel base of that?
sorry if I'm being lazy.
thanks
Posted : 05/08/2015 8:36 pm
670mm TT with a 76D STA is gonna make that a very long frame when stood up.
Also, you don't design a frame around reach and stack; they're just the outcomes after the geo of the frame has been sorted.
Posted : 05/08/2015 8:55 pm
There are quite a few online calculators of various degrees that will work that and more out for you
Posted : 05/08/2015 9:06 pm
Pencil and paper. Or Bikecad.
Maybe start with where your hands, feet and bum go....
Posted : 05/08/2015 9:10 pm
Long is good, as it been put i have a body like an orangutan.
Thank you all, this will be a learning curve then.
Posted : 05/08/2015 9:12 pm
That's a long bike.... Probably about 1260-1270
Posted : 05/08/2015 9:16 pm
Thats were roughly I was thinking it would be.
Posted : 05/08/2015 9:19 pm
Nicolai still do custom frames, could be worth talking to them.
Posted : 06/08/2015 8:23 am
Yes but that is LONG.
Rule of thumb would be each degree on the seat angle adds/subtracts a virtual 10mm to the top tube, so a 76deg seat angle gives 40mm more room when stood up over a conventional bikes 72deg. So a your top tube would have a similar reach to a more conventional bike with a 710mm top tube! And that seat angle is very steep, are you 100% sure you can actually pedal at that angle, I know I can't with anything steeper than about 74 or 75 deg.
Also remember that with dropper posts seat angles need to be ~2deg slacker as you've lost the 25mm of layback that normal posts had.
Your framebuider should be able to help, and would hopefully tell you when you've gone wrong.
Posted : 06/08/2015 8:38 am
It is. Making some assumptions on BB drop and HT+fork length I get 1270mm+.
The length wouldn't concern me, it is longer than normal but only 70mm or so. It's a custom after all.
Posted : 06/08/2015 10:47 am
+1 for bike cad.
& why 76° Seat?
Posted : 06/08/2015 11:26 am
From my very basic clacs WB = 1275
Posted : 06/08/2015 11:37 am
