downtube protection
[Closed] downtube protection
15 Users
I took my giant trance out yesterday and the downtubes taken a battering from rocks flying up from the front wheel, I don't think the frames a write off, but I'm keen to avoid any further damage to the area. I'm thinking it needs a bit more than the usual frame tape, some sort of hard plastic device made specifically for the frame would be ideal. Anyone know whether such a thing exists?
Posted : 28/10/2012 8:13 am
Check out rockguardz on eBay, they do carbon bash plates for a few frames that just clip on your down tube, trance is fairly common so should be able to get one, if not they'll do you a custom one if you can get your bike to them.
^ beat me to it!
Posted : 28/10/2012 8:19 am
 Andy
Old tyre zip tied to downtube works as well as anything
Posted : 28/10/2012 8:20 am
I don't see how a tyre will stop rocks denting the frame? Maybe pebbles and wee stones won't chip the paint, but I'm sure we're talking about fist-sized denters here!
Maybe you can put a strip of something under it first?
Posted : 28/10/2012 8:24 am
Common problem. The dent will usually be an inch or two from the bottom bracket ... thats where it had my ellsworth epiphanys anyways!
Just zip tie a piece of angle alu or angle plastic to cover the bottom 5-6inches from bottom bracket. The angle will deflect any stones coming up.
Posted : 28/10/2012 8:34 am
glasgowdan - Member
Well if it's rocks that are big enough to dent the downtube through an old tyre, then they'd make pretty short work of a carbon protector
Posted : 28/10/2012 8:37 am
Tyre if your that bothered frame tape otherwise.
Posted : 28/10/2012 8:42 am
That carbon fibre rockguardz thingy looks lovely. Will be gettin myself one of those!
Posted : 28/10/2012 10:09 am
It was last year i looked into them guards, consensus was the fit wasn't always great so i didn't bother. Check the feedback
Posted : 28/10/2012 10:24 am
Mousemat zipped to the tube works perfectly on a titanium frame of mine.
Mousemat has the neoprene base under a hard polymer skin.
I fitted it with the hard skin outwards.
Cost nearly zero.
PaulD
Posted : 28/10/2012 11:29 am
We use a chunk of tyre zip tied to the downtube, You'd be surprised at the damage they stop as the rubber absorbs a lot of the impact. Give it a try, either way it will stop some of the damage and you may well be pleasantly surprised. We were and we get some pretty big rocks flicked up, believe me!
Posted : 28/10/2012 11:32 am
I'd seen those Rockguardz too - anyone actually got one?
Posted : 28/10/2012 12:09 pm
As long as you can physically get the thing on you can always zip tie it to death to keep it on
Posted : 28/10/2012 12:14 pm
I have a rockguard and very nearly sent it back upon arrival.
I have pics somewhere but the quality and finish is poor. It fits on to the frame (just) but is 1 layer of carbon, twisted, and not cut to shape symetrically.
A few friends I have shown said to return it, but I thought if it was going to be hit by rocks then it's better to use it than not. If it smashes off I will not replace it certainly not at over £30
Posted : 28/10/2012 12:24 pm
I just helitaped my new frame yesterday, don't think I'll go as extreme as carbon fibre sheets
Posted : 28/10/2012 12:46 pm
 JoeG
[url= http://www.zefal.com/en/protect-and-repair/194-down-tube-armor.html ]Zefal[/url] make a universal one.
Posted : 28/10/2012 3:23 pm
