Downhill UST Mud Sp...
[Closed] Downhill UST Mud Spikes (Other than Wetscreams)
5 Users
As the world seems to be sold out of UST screamers is there an alternative? Any help would be most appreciated. Anyone who says stick a tube in a regular wetscream will be ignored.
Lots of love
Vegi
Posted : 20/10/2009 5:57 pm
swampies?
it has to be proper nasty for screamers to really come into there own, if its that gopping then i generally don't bother.
Posted : 20/10/2009 6:01 pm
as jambo said,
has to be mental muddy to be worth running wet screams, swamp things for general winter dh dutie's.
schwalbe do the muddy mary...
Posted : 20/10/2009 6:18 pm
I did try swampies for a bit, but i feel much more comfortable on a spike. Its probably worth mentioning that im a HUGE spike fan. I run F:Half cut down R:Full cut down in the dry, and F:Full spike R:Half cut in the wet. I also (but rarely) use minion DHFs F+R in the dry. So really im looking for a UST wetscream, but not a maxxis cus they are sold out.
Also id like the moon on a stick if you've got one going spare.
Posted : 20/10/2009 6:19 pm
why the hell would you run wet screams in the dry?
even cut down ones will give you much less grip in the dry than a high roller/minion!
Posted : 20/10/2009 6:24 pm
Michelin Mud 3 - probably even harder to get hold of than any of the above.
I have 2 unused in my garage ready for this winter and I love them... apart from the nearly 1.5kg weight.
Not a UST tyre but I run them that way with no problems.
Posted : 21/10/2009 10:11 am
Thanks Messiah, do you run them on tubeless rims or with a tubeless kit. (Stans etc.)
Posted : 24/10/2009 7:11 pm
Dual ply maxxis tyres work fine for tubeless. I've used loads of them on UST rims, ghetto and Bontrager tubeless wheels. Make sure you use a latex based sealant like stans if you do this.
Posted : 24/10/2009 7:14 pm
