Bike Forum
3
Posts
2
Users
0
Reactions
647
Views
ive just got a set of these. However while trying to install them i found that on both levers the stroke adjustment screw does not turn. Â I read it is shipped with minimum contact gap so need to turn to the +but it did not budge clockwise or anticlockwise.
What am I doing wrong?
 Its the little screw accessed behind the lever that I can’t turn rather than the lever reach adjustment dial that is through the lever, which i can turn.Â
Posted : 22/05/2025 8:18 pm
Have you found the grub screw that you need to undo first?
Posted : 23/05/2025 3:10 pm
grub screw, as in one of the bleed ports?! I actually discovred it's only on one lever that the stroke screw isn't turning, the otherone is but I was being ultra careful initially as didn't want to round the head as it's only a 2mm allen key.
Posted : 24/05/2025 7:47 pm
