Does this frame exi...
[Closed] Does this frame exist, help me shop 🙂
6 Users
Hi all,
I'm after a new 29er hardtail and would like some help please. I’m looking for an XL size and the ideal must haves are;
• a high stack of at least 640mm upwards.
• internal dropper post routing for 30.9 ideally
• rear clearance for 2.35" tyres
• suited to 100/120mm forks
• cost under £500
I’ve been looking at the Orange Clockwork but so far I’ve been unable to confirm the tyre clearance. I’m also considering the Whyte 529/629 but unsure of dropper routing capability. I will consider a full bike and then sell on the parts I’ve stripped off. Happy to consider alu or steel. What else would you suggest I consider?
Thanks 🙂
Posted : 05/06/2017 2:34 pm
 Bez
I think this broadly ticks the boxes. You'll want a 5mm headset spacer to ring the 640mm stack bell, but you should be able to afford one with the change from £500.
https://www.evanscycles.com/pinnacle-ramin-2-2016-mountain-bike-frame-EV271759
Posted : 05/06/2017 2:40 pm
Cheers Bez, that pretty much does but I don't think it takes an the internal dropper and looking back at my post I have no idea why I typed ideally when I should have typed must!
Thanks again
Posted : 05/06/2017 3:03 pm
 Bez
Oh, I missed the "internal" bit anyway 🙂
Posted : 05/06/2017 3:12 pm
At £150 i'd be looking at shimming and drilling if you already own the dropper post!!
Posted : 05/06/2017 3:26 pm
That's a thought I could go down that route.
Anyone else have any suggestions?
Thanks
Posted : 05/06/2017 8:52 pm
The Whytes you mention do take stealth dropper routing.
Why an xl. Are you very tall. The ett on my large 529 is something like 655mm.
Posted : 05/06/2017 8:58 pm
That Ramin frame is a good find at that price.
Posted : 05/06/2017 8:59 pm
It is a good price isn't it. I need to try one for size, the last one i tried was crazy small for me.
That's good to know Renton, I'm 6ft 4 but more body than legs, I look ridiculous to be honest. I've got a SolarisMax at the moment that has a 657 top tube and that came with a 60mm stem which I changed to 80mm. I like long, I hate low. Could I fit a 2.35" tyre in the rear?
Posted : 05/06/2017 10:16 pm
I would imagine the Clockwork will take a decent sized tyre, most Oranges do. Give Fulford Cycles, Stif, or Orange themselves a ring to confirm.
Posted : 05/06/2017 10:30 pm
