My trusty commuter was in at the lbs for a bit of tlc when I get the call.... Bottom bracket area is cracked so frame is done in. Initial reaction was sh1t but then I thought, time to crack out the credit card and work on n+1.
I would quite like to go down the disc brake route for commuting but that obviously means investing in new brakes, wheels and frame and fork. Is there are commuter/cx frame and fork out there which has mounts for both discs and standard caliper brakes allowing me to upgrade at a later date or do i have to take the hit now?
Should add that as it's getting year round use I need guard mounts and possibly a rack mount!
Cotic x has both but you can't buy them new anymore afaik
Most disc brake frames are 135OLN rather than road standard 130.
sorry wrong answer from me
Most of the CX/Hybrids have mudguard mounts.Also most are disc only.Plenty on the market Trek croossrips/Meridas/Genesis etc.
Take the plunge, go disc. I did and I wouldn't go back, especially for commuting.
I run a kinesis tipster and it's brilliant but if you are on a budget the London Road from planet X has 30% off at the moment so it's only £210 for a frame and carbon fork. Frame is disc and has rack and mud guard eyelets.
http://www.planetx.co.uk/i/q/FRPXLONROD/planet-x-london-road-frameset
