29er
steel
140/150mm fork
65 ish h/a
75 seat
44/44 h/t
rack mounts
decent number of frame mounts
routing for front mech
seem to be coming up short with a few things so any suggestions?
Can you get a custom one built? Marino at one end of the budget and Curtis, etc at the other end.
Bomtrack Cale gets fairly close to your wanted geometry and has mounts:
https://www.bombtrack.com/gear/p/cale-frame
Possibly more slack but fewer mounts are Sour Bikes Big Fun or Crumble.
https://sour.bike/
Front mech routing you'll probably just need to use clamp on mech. Clamp on cable stops can be got from SJS cycles, I think problem solvers make some.
the solaris looks nice but no rack mounts.
marino custom crmo build would be £376 posted so definitely in the mix.
Bombtrack has too short a travel plus i don't like it when there's no price on the product.
Not sure if the Spa Cycles Rove 725 can do the suspension aspect
It's a fair way off the Head angle requirement too.
There really aren't many new MTB frames about that will take a front mech, even fewer with less than 68° head angle.
custom it is then
