Does the "frid...
[Closed] Does the "fridge trick" work ok on Hope Evo rear hubs to change bearings?
7 Users
You know the one, cool/freeze bearings in sandwich bag in freezer, warm hub with hair dryer.
I used such a method on an OEM hub many moons ago but does it work on on the Hope Evo hubs?
I know it should in principal, but in principal can turn out to be a nightmare in the real world!
Thanks for the help as always guys.
Posted : 08/01/2015 11:16 pm
Can't see why not although I've never had to try. My Evo's are only 5 yrs old. 8)
There again, If you've got them out, what's the problem getting them back in?
Posted : 08/01/2015 11:21 pm
Not got them out as yet. Planning ahead...
Pretty confident I can remove them with some improvised drifts. Want to be a bit gentler putting new ones back in though. lol
Posted : 08/01/2015 11:28 pm
You'll be fine getting them out with a good drift & some support. Then 'simply' bash them back in using a big hammer & the right sized socket. 😆
Cool the bearings & warm the hub up to make it easier if you like though.
Posted : 08/01/2015 11:38 pm
Great, last question, any idea of socket sizes I need as drifts?
I realise the OD of the socket may be different according to brand, but just want a starting point, cheers again.
Posted : 09/01/2015 1:24 am
About 24mm iirc (same size as rockshox damper topcaps).
Posted : 09/01/2015 6:38 am
Thats handy, just ordered a 24mm to service some Revelations.
Cheers for info!
Posted : 09/01/2015 12:51 pm
Never needed to chill bearings when I've swapped them - brute force, ignorance and a healthy supply of profanities usually suffice - but it is sound engineering practice to do this.
I know on larger steel bushings on earthmoving equipment, OEM assembly lines will use liquid nitrogen (WARNING!: do not drink, even when mixed with Red Bull or Monster).
Posted : 09/01/2015 12:54 pm
why not use the old bearings and some threaded bar with washers to push the new ones in? this has worked ok for me (actually thinking about it, I used a QR skewer)
Posted : 09/01/2015 12:57 pm
I've changed all bearings on both my sets, whacking the old ones out with the axle and I had an appropriate diameter drift turned on a lathe to get them back in. you need an outer diameter of 30mm and it works for both front and back. Didn't need to drink any liquid nitrogen but a little bit of grease helped them back in smoothly.
Posted : 09/01/2015 12:59 pm
Hmmm.... good point, might give that a try too, cheers.
I found it cheaper to just buy the drifts from HOPE.Used a block of wood with a big hole drilled in it to support the backside and allow somewhere for the bearing to drop into.
Posted : 09/01/2015 2:30 pm
Agree, the right tool for the job is the best option definitely.
As usual, trying to save a bit of money is all. Particularly post Christmas.
If I try the nitrogen route I'll be sure to take pics! (that's a joke, I wont be trying the nitrogen. Sounds like an interesting method though!)
Posted : 09/01/2015 8:14 pm
