I'm looking for a new tent and have a good idea what I'd like from it. However, I can't find anything which fully fits the bill ... I would like.
• 1 Person
• Double skin
• Outer pitch first
• Extended front porch
• Under 2 kilos
The nearest I can find are a Lightwave t0 Trek XT but it pitches inner first or a Vango Spirit 200+ which fits the criteria but been 2 man will bump the weight up to around 2.6kg.
Anyone got any other ideas? I know you can get an extension for some of the Big Agnes tents but I think they might pitch inner first too.
Thanks
Stuart
[url= http://www.theoutdoorshop.com/showPart.asp?part=PN57205 ]It doesn't pitch outer fist, but its an awesome bit of kit....[/url]
hilleburg akto?
Vaude Taurus Ultralight sounds close to what you want. Depends how big a porch you want.
yes it does and I have one
Mine doesn't. None of them come with a cast iron guarantee that it won't p*ss down as soon as I pitch it. 😕
Macpac Microlight? If it's anything like my Olympus you will be able to unclip the inner, pull it back, and make a bigger outer space for cooking etc. and it's multipitch, so you can pitch all at once or outer first. [url= http://www.theoutdoorshop.com/showPart.asp?part=PN70309 ]Macpac Mircolight[/url]
We have the same tent teeto has linked to.
It's a great bit of kit. Loads of room inside too.
It's that big inside I recon even wokboy sheldon could get in.
Edit.
Looks like they do a one man version too. Though I dought fatnacker Don would get into that one. 🙄
[url] http://cascadedesigns.com/msr/tents/fast-and-light-tents/hubba-hp/product [/url]
I'll have a look at the make and model when I get home, although it's 2 man it's 2 very friendly men. and I think it's just over 2 kilos.
So in fact no, but quite close
As you suggested [b][url= http://www.lightwave.uk.com/en/tents_t0.php ]Litewave[/url] Great stuff - and British (in a via China kind of way) Great gear and 2mans are also superb kit.
Or
[url= http://www.gaynors.co.uk/products-Mountain-Hardwear-Viperine-2-Tent_040201410007.htm ]Viperine2[/url]
I know its offically 2 man and 2.16kg but it can be put up fly 1st then hook in the liner. Great tent i think and nice option to go flysheet only and Pitchlite for a big weight saving. It's semi geodesic so you really only need 2 pegs saving even more weight unless its truly dreadful conditions.
Ta folks ... thinking about it Stu I saw yours (tent) at Brecon last year and it did look nice. Is it classed as a 2 man or Sheldon tent then?
Macpac could be a possible ... I'll check about pulling the inner back. Not sure if my pockets are quite deep enough for an Akto and it looks like a Terra Nova which puts me off.
you can pitch the msr hubba outer first.
Found it, 'tis a poxy Millets own brand though, but had mine years and it's fine and has never leaked. Only UK stuff though but it has weather soem heavy rain.
Pitch the outer first and hang the tent off the inside.
Weight: 2.3kg
Pack Size: 14 x 46
Polyester Fly Sheet
Taped Seams
Hydrostatic Head = [b]1500mm[/b] (suprised by this as I've been in some right old rain and never got wet)
Waterproof Ground Sheet
Just looked at the Millets site and it's £30 FFS! but is a newer different model and weight has gone up to 2.8kg
Other than that Decathalon do one, friend used one on a Bivvy trip (cheater) anyway it looked good but that was pitch inner first
in fact here you go http://www.decathlon.co.uk/EN/lightent-3246909/
He doesn't need a tent he just throws a tarp over his wok.
Our is a two man though.
porch might be too small though but fits every other criteria.
I've got one of [url= http://www.millets.co.uk/product/093076.html ]these.[/url]
Not a huge amount of porch space, but there is room for me to sleep next to a weekend's load of clothing etc. Also is a breeze to put up, and is tiny and light when packed away.
The Macpac Microlight does have a porch, I was just sayin, that being able to make a bigger porch when you're cooking etc has been a great feature on my Macpac tent. Also, the multipitch, you can put the tent up in seconds.
As mentioned above, a Hilleberg Akto. It does all the above with a large porch. What exactly do you want from the porch. You aren't that clear.
to put his tea urn in.
Apart from fitting in my tea urn, I'd like enough room to store wet gear, sit up and *cook that's why I'm wanting something with an extended porch or an extendable one as B.A.Nana says.
* Please no moaning about cooking in porches, it's something I do, end of. 😉
Big yes for the Hubba Hubba. It's withstood some serious Scottish wild camping and with a little practice can be pitched/de-pitched in whatever order you like. MSR also do 1 man variants. The side porch is the thing that we like, so much easier to live with compared to a front porch imo.
[url= http://www.tarptent.com/scarp1.html ]Tarptent Scarp 1[/url] might be worth a look
Apart from fitting in my tea urn, I'd like enough room to store wet gear, sit up and *cook that's why I'm wanting something with an extended porch or an extendable one as B.A.Nana says.* Please no moaning about cooking in porches, it's something I do, end of.
Just cook in the tent like the rest of us you big jessie 🙂
Just realised I linked to the 2 man MSR Hubba...
Mines the 1 man version...
And for me, it's perfect..
Macpak microlight is a great tent, outer or inner pitch first, porch and decent siting height
well under 2kg
