Does a steel frame ...
[Closed] Does a steel frame need a steel post and steel clamp?
4 Users
...at least, what's the recommended practice on this? Does the metal the clamp is made from matter?
Posted : 24/09/2013 9:24 am
not at all.
just make sure you keep everything well greased and take the post out the frame every now and again to check for corrosion.
Posted : 24/09/2013 9:25 am
Mine has a carbon post and alloy clamp, never had any problems. I wouldn't worry about using an alloy post either just move it every so often to check you still can.
Posted : 24/09/2013 9:27 am
Ah, looking more closely you can't get steel clamps can you.
Presumably clamps don't get stuck like posts due to electrolytic things going on between steel and alu then?
edit: oh look, replies ^^^ cheers 🙂
Posted : 24/09/2013 9:28 am
a thin layer of grease works wonders
Posted : 24/09/2013 9:29 am
I'd say the paint on the outside of the frame will protect the clamp.
Posted : 24/09/2013 9:30 am
Cool, nice one. Yes, that figures. In any case the surface contact area of the clamp is tiny compared to the post.
Posted : 24/09/2013 9:32 am
