No but you could stop asking silly questions.
Blob of araldite, it'll be fine.
Nothing a bit of blu-tack wont fix.
A bit of duck tape and a zip tie?
Send them to me, and for £399.99 I'll have them back to you, looking like new, complete with chainrings.
PayPal gift?
HOW?
Trail fix it with a stick though the middle.
HOW?
Overtightened the preload thingy, I bet 🙂
u is awsum.......
It's just a sticker. Nothing to worry about.
Blimey, it tore the bearing out of the BB cup!!
Landing from a jump/drop by any chance? Looks like a torsional failure. Nice one.
I guess technically you could get someone to weld/braze a tube/shaft up the middle but realistically sell the none drive side and hang the drive side up and be proud.
What do [i]you[/i] think? 😕
Must have installed them with a rock.
I'd do the same kinda thing as if I were making a DIY headset press, so just poke a bit of studding through the middle, shove a fat repair washer on either end, topped off by a nyloc (or a domed nut if you are feeling posh) and crank it down with a couple of foot of scaffolding pipe on the end of the spanner - what could possibly go wrong?
I guess if you were concerned, you could shove a bit of MDPE water pipe or something over the studding to save it moving around [i]too[/i] much in the BB shell?
This is a classic failure - I bet the OP fitted 650b wheels and the enhanced trail liveliness has fed back up the drivetrain
It's lucky the axle failed - your ankles were next in line
The spiral bit is a classic torsional failure.
I think you already know the answer about repairing them....
That will just T cut out.
