Do N/W click and ti...
[Closed] Do N/W click and tick?
9 Users
Mine does! Could be PF bb? Could be pedals? Could be KS lev dropper?
True..
But it only seems to happen in some gears, so I'm assuming it's the NW ring clicking at certain points as the chain settles into place with certain pressure?
Oh... And other than filling the tubes with expanding foam (lol) I assume there's not a way to stop the internal cable rattling? It's as annoying as a noisy eater that talks with their mouth full!
Posted : 11/01/2016 10:14 am
mine did for a bit.
but only because the bolts weren't done up tight enough.
Posted : 11/01/2016 10:19 am
Oh yea good point.... but why click and creak in only some gears not all?
Posted : 11/01/2016 10:45 am
I've heard of people putting foam tape around rattling internal cables (though I have no idea how you do that!) Seems a massive case of form over function which I'm hoping will go away...
I think my N-W rings used to click on the biggest sprocket where the chain angle is most extreme but it only happened when they were new.
Posted : 11/01/2016 10:52 am
One of mine was a little noisy when new. Mate who worked in a bike shop has a theory that they get quieter once some of the anodising has worn off the teeth. This has indeed happened with mine.
Posted : 11/01/2016 10:56 am
Have got 4 NWs and ime the bigger they are the more they click
The 36s seem quite intolerant to chain line
Posted : 11/01/2016 10:57 am
Especially once they are wet and muddy. I've put it down to the tighter tolerances in an 11 speed setup.
Posted : 11/01/2016 11:12 am
Ok thanks chaps it is quite a new ring. Bolts are tight. Greased seat post, clamp and bolts, also done seat bolts and rails. I'm sure the rattly cable will annoy me less with time it's just new to me and noisy compared to my HT. Hopefully it will settle and it's not something like the BB or pivot starting to go.
Posted : 11/01/2016 11:14 am
Dbl post
Posted : 11/01/2016 11:24 am
I've always found them to be quieter.
The only time i got noise was when my chainline was out a mm or so. is it in the largest 2-3 cassette sprockets when the noises start? if so, the chainline is probably too far out and you'll need to space the ring in a mm. 4 washers under the crank tabs will sort that.
Posted : 11/01/2016 11:45 am
I'm 1x10...dont think it's chain line issue. More investimagation needed.
Posted : 11/01/2016 3:28 pm
i found 1 x 10 was worse than 1 x 11, especially in the lower (larger) 3 sprockets
Posted : 12/01/2016 8:57 am
Hmm rode it to and from work, not a single click. Oh well. Ride on Macbeth!
Posted : 12/01/2016 9:04 am
Mine was quiet from new, however I'm running 1x8 so I guess the wider chain may have something to do with it.
Posted : 12/01/2016 1:06 pm
I had it on a 1x10 bike where the chainline wasn't perfect. It clicked in the biggest cog at the rear when climbing steep hills. I couldn't figure it out until one day I was working on the bike in the stand and back pedalled it. I could see the chain trying to be dragged off sideways and making the clicking noise. I adjusted the chain-line and all is now well. I had blamed it on many things up until that point.
Posted : 12/01/2016 1:16 pm
if chainline is out, even a tiny amount of grit can make a right old racket.
it can look spot on, but it won't be.
Posted : 12/01/2016 1:43 pm
Well the more I ride, the more I think it probably is the BB. Mainly because there's no clicks when I freewheel, but when I pedal, the clicks happen.
Regreased saddle rails, saddle bolts and seat post. Regreased seat post clamp. Checked bolts on chain ring. Took pedals off, cleaned and regreased. Checked lock ring on cassette.
So... Let's hear suggestions for a new BB for a 2015 Trance! It's an SLX chainset at present so I guess a new Shimano job? Steel? Ceramic? 3rd party?
Posted : 13/01/2016 1:19 pm
