Hi just tried to put a triple chainset on a 2015 orange crush 650b but the outer ring catches the etype front mech. So decided as i dont use it i took the outer ring off. Right i get it all back on running double , get it all set up in the stand shifting nice, then as soon as i go out on the road the smaller ring seems to lift the chain up into the frame and gets stuck. Would a chain device help this. Thanks
If you took the outer ring off, and didn't put a bash guard on - then your chainring bolts will be sticking out into the small ring.
You'll need shorter bolts to run a double without a bash guard.
The other issue you will find is that your middle ring is ramped, so designed to help the chain move up to the big ring - without the big ring the chain will likely fall off.
The easiest option overall is to get a bashguard, and fit it.
Thanks see what your saying but i made up some shims to replace where the outer ring was . At the moment this happens as about 2mph and only in the granny ring. Ive had chain suck in the past on other bikes but not at such a low speed, could it be the granny ring as ive put new chain and cassette on but left the old granny ring on?
Ramps on the middle ring are only to aid shifting from the granny to middle. Its the ramps on a big ring that help the chain shift up to the big ring.
Could be. Do your teeth look hooked?
That's chain suck, nothing to do with a chain device unfortunately. Check for wear/damage on the ring first
New chain + worn out old chainring = chainsuck, n'est-ce pas?
