Do I NEED a Shimano...
[Closed] Do I NEED a Shimano 12 speed chain as well?
5 Users
Just ordered some SLX 12 speed cranks to go with the rest of the Shimano drive chain. I've got a new SRAM chain on there at the moment.
Do I need a Shimano chain as well or will the SRAM chain / Shimano ring play well enough for now?
Posted : 21/10/2020 12:10 pm
I use a sram chain with 12 speed Shimano one one bike, and a Shimano one on the other - works ok... slightly different but perfectly good. Use the chain and replace it with Shimano once it wears out.
Posted : 21/10/2020 1:12 pm
perfect. thanks.
Posted : 21/10/2020 1:19 pm
No problem mate
Posted : 21/10/2020 1:21 pm
Sram chain works on Shimano 12 speed, but so say not as slick as a Shimano one.
It’s the other way round you can have an issue - the Shimano 12 speed chain doesn’t play nicely with a Sram chainring. Although it might just be the Shimano 12 speed link is the problem rather than the whole rest of the chain.
Posted : 21/10/2020 2:41 pm
I think it is the Shimano link that's weird Joe. I swapped the link on my Shimano chain after it fouled an absolute black oval ring... added a sram one and it worked perfectly...
Posted : 21/10/2020 4:01 pm
To get the full benefit of HG+ you need the shimano chain, you're losing the shifting under load smoothness of shimano 12 speed.
Still works with other chains just not optimal performance.
Posted : 21/10/2020 10:17 pm
I'll give the SRAM one a go to start and switch to a shimano one later if need be. The Freewheel discount means a Deore one is £20.
Posted : 21/10/2020 10:44 pm
 LAT
i don’t think that the deore chain is HG+. you’ll need slx or above for the plusness
Posted : 21/10/2020 11:19 pm
https://bike.shimano.com/en-EU/product/component/deore-m6100/CN-M6100.html
Deore is
optimized for HYPERGLIDE+ cassettes and DYNAMIC CHAIN ENGAGEMENT+ chainrings.
Posted : 22/10/2020 12:01 am
