do groupsets come w...
[Closed] do groupsets come with cables?
6 Users
Just ordered this http://www.chainreactioncycles.com/shimano-ultegra-6800-11-speed-groupset/rp-prod110818 but no idea if it would come with cables or if i need to go and spend another £50+ on them?
Posted : 21/11/2013 10:27 am
Should do.
Posted : 21/11/2013 10:30 am
As wnb said, however seeing its CRC anything is possible depending how grey it is.
Posted : 21/11/2013 10:33 am
ok, i suppose i could wait really and see when it gets here but will want to fit it all straight away. Ill try and be patient.
Posted : 21/11/2013 10:40 am
should also come with boxes bt its not always the case!
Even if that group did drop out of the first container coming out of China, it should come with cables.
Posted : 21/11/2013 10:42 am
Biggest issue i just noticed was that my hubs are not compatible with 11 speed cassettes, guess what that mean? new wheels 😀 I can justify spending this money though as i was going to buy a new bike in the spring, now all i need to do is buy a frame..........
Posted : 21/11/2013 12:01 pm
Inners only on mine from merlin
Posted : 21/11/2013 12:12 pm
If you look under [b]'Questions'[/b], there's the following:
Are all cables supplied (including polymer coated gear cables)?
This group set is not supplied with the cables. You would have to buy them separately.
So no.
