Do carbon rims ...
[Closed] Do carbon rims 'ping' and creak as you pump up the tyre?
7 Users
As per title, just fitted some tyre to some 700c 50mm deep carbon clinchers and as I got them up to pressure, it sounded like there were a few creaks and cracking noises.
I'm assuming this is just the equivalent of the twangs and pops you hear when the bead seats on a metal rim?
Posted : 01/05/2014 8:24 pm
Probably just the tyre seating or the spokes un tensioning or moving a little perhaps.
Posted : 01/05/2014 8:28 pm
That's what I thought too. They're from a UK supplier, so I'm not too worried, just checking.
Posted : 01/05/2014 8:32 pm
Creaking is a little odd, sure it's nothing to be worried about, but not common.
Posted : 01/05/2014 8:42 pm
Yep, a kind of twang-come-crack, the first time the tyres have been fitted on the rims.
Posted : 01/05/2014 8:46 pm
Did read relatively recently that tight beads on a tyre can de-tension the spokes. Can't remember the full argument around it though.
Posted : 01/05/2014 8:55 pm
Twang-come-crack is more normal - that sounds like tyre beads settling. Creak implied prolonged to me.
Posted : 01/05/2014 9:37 pm
Twang-come-crack
Sounds like a village in Somerset.
Posted : 01/05/2014 9:39 pm
Thanks Boxfish....I have to say I did hesitate to use the phrase 'twang-come-crack' 😉
Yep,Njee, it was a few random crack...crack...twang.....silence.... Did sound akin to a tyre seating on a metal rim but (perhaps unsurprisingly) plastic-y and as though something was almost snapping.
I read somewhere that carbon clinchers should be kept with the tyre deflated when not in use. Anyone else heard this?
Posted : 01/05/2014 10:05 pm
Nope only high end track tires ( ultra high pressure and no sidewall protection) need to be stored deflated.
Even thats only because brushing a sharp object st the ultra high psi can maye the tensioned fibres let go.
Posted : 01/05/2014 10:21 pm
Cool, I've left them pumped up anyhow for now.
Posted : 01/05/2014 10:26 pm
Yep, no reason to deflate them.
Posted : 02/05/2014 5:36 am
 Sam
Sounds like spoke wind-up settling. Shouldn't happen on a well built wheel.
Posted : 02/05/2014 5:47 am
