DMR Vault service
[Closed] DMR Vault service
6 Users
Holla,
Am doing this for the first time myself - got the tools and have bought bearings and bushings - non DMR [that £25 service kit is a joke] - but....
The one thing I'm am not sure on is replacement internal rubber seals - I can see that one is a bit damaged - I think the bushing is slightly out.
Can anyone tell me please what I need / where to get them?
Cheers, Al
Posted : 11/05/2021 3:03 pm
Following cos I need to service my Vaults too. Where did you get the bearings / bushings from out of interest?
Posted : 11/05/2021 3:41 pm
https://www.onlinebearings.co.uk/DU-Series.html
https://www.amazon.co.uk/gp/product/B07MKJT525/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Generic bearings, nothing special. See how I get on. The pair on there are pretty old and have been rebuilt at least once.
If I need to bin them, I will, and get cheaper disposable pedals - Welgos, or HTs.
Posted : 11/05/2021 3:59 pm
 colp
These are the best option for replacement bushings:
https://www.ebay.co.uk/itm/174750925765
Posted : 11/05/2021 4:14 pm
Any thoughts on the rubber seals?
Posted : 11/05/2021 6:44 pm
Ta very much 🙂
Posted : 11/05/2021 6:50 pm
Mine need new spindles. Actually the bearings were fine. But there is still play in the bushings even with new bushings
Posted : 11/05/2021 8:15 pm
 goby
I just bought some v ring seals from eBay.
Posted : 11/05/2021 8:21 pm
 colp
@goby
Was it these?
https://www.ebay.co.uk/itm/V-Ring-Seal-For-Shaft-Sizes-11-5mm-12-5mm-V12A-/123702552099?_trksid=p2349624.m46890.l49286
Bushings are 12mm ID 14mm OD so these look good.
Posted : 11/05/2021 10:44 pm
 goby
@colp
Yep thats the ones or it could have been the next size 13.5-15.5, just double check and measure the axle diameter where the seal sits. They seem to work ok.
Posted : 12/05/2021 7:59 am
@ampthill
Where did you get the replacement spindles from? My Vaults need a complete overhaul, however with new bushes, spindles, bearings and seals I may as well buy some V11s or if you look around Vaults are coming in around £74.
Posted : 12/05/2021 10:14 am
@asbrooks mine need knew spindles but I haven't bought any yet
Posted : 12/05/2021 10:46 am
 goby
@asbrooks
I got some new axles from here
https://www.upgradebikes.co.uk/Catalogue/Pedals/Spares/DMR-Vault-Pedal-Axles
Posted : 12/05/2021 11:59 am
 colp
@ampthill
Do you have a micrometer?
Brand new Vault spindles are exactly 12.00mm at the bushing section (I just checked) worth checking yours.
Posted : 12/05/2021 10:58 pm
