diy bike wash
[Closed] diy bike wash
12 Users
I think pressure washers are too strong and garden sprayers don't hold constant pressure, so I modified one
Posted : 03/01/2015 10:11 am
Uh, ok?
Posted : 03/01/2015 10:12 am
Well done !.
Posted : 03/01/2015 10:15 am
I presume there is meant to be a pic or link...?
Posted : 03/01/2015 10:16 am
Pressure washers are fine if you get a small one.
Posted : 03/01/2015 10:24 am
Chuck it in the canal.
No, wait....
Posted : 03/01/2015 10:26 am
What happened to monkey?
I have a dirt worker and small kercher and am just gentle around pivots etc. No problems.
Posted : 03/01/2015 10:27 am
Yeh pressure washers are fine, but 12v portable ones expensive this is ok for cleaning it enough to put it in car. And if you already have a 12v air pump sorted
Posted : 03/01/2015 10:33 am
I put it in the car dirty. A tarp keeps the car clean.
Posted : 03/01/2015 10:35 am
singletracksurfer - Member
I suspect his casual jiggery and possible pokery has led to a fireball of death.
Edit: No, it appears I am wrong. As well as slow.
Posted : 03/01/2015 10:36 am
So was there meant to be a photo or something? I'm none the wiser...
Posted : 03/01/2015 10:41 am
cant figure out how post a pic, my first post
Posted : 03/01/2015 10:59 am
Every half dozen rides or so wait for the kack to dry, knock/scrape off the worst of it and wipe off with a damp cloth. Life is too short to spend it washing your bike. I give the drive train a wipe down and re-lube after every ride.
Posted : 03/01/2015 11:03 am
Hose. Soapy cloth. Hose. Lube.
Sounds a bit wrong written down that.
Used to use a Karcher, but the 'manual' way seems just as quick, kinder to the bike, and more effective.
It's definitely not quicker for me to use a bucket and cloth. Jetwasher is very quick, especially as it sorts the chain out in seconds too.
Posted : 03/01/2015 11:05 am
No worries dude.
Check this out.
http://singletrackmag.com/forum-help/
Posted : 03/01/2015 12:31 pm
Jet wash whilst mud is still wet, avoiding direct onto bearings, dry off with an old towel. ptfe spray over the mechs and pedals, wet lube on the chain and a drizzle around the seals of the bouncy bits. Done in 10 minutes and bike is always spangly and working perfect.
Posted : 03/01/2015 1:13 pm
