Dismantling a Marzo...
[Closed] Dismantling a Marzocchi 44 RLO to extend the travel from 120mm to 140mm
1 Users
Said I'd do this for a friend....there's an allen bolt at the bottom of the air leg and an unscrewable nut housing the schraeder valve on the top of the same leg......
But on the other leg, its a lock out lever top and a rebound adjuster knob at the bottom. Do these pull off to reveal bolts or is it just the other leg holding things together?
Also, what weight oil do I need and how much?
Are instructions available for this mod, I can't believe its difficult but they're not my forks so I don't fancy mashing them (and he's going to worry if he reads this anyhow...;-)
Posted : 06/05/2011 7:23 pm
