Disc rotors
[Closed] Disc rotors
7 Users
Are all disc rotors the same thickness? I need a new front rotor as the current one is ever so slightly warped and rubs on the pads. I have M960 calipers but want the flowery hope rotor. Will it work or am I better sticking to shimano?
Posted : 06/07/2012 6:14 am
Usually it works, the pads can sit where they need to to accommodate.
You can also true your existing rotor.
Posted : 06/07/2012 7:04 am
I've been using Hope discs with Shimano XTR calipers (M960 & M970) for several years without problems.
Posted : 06/07/2012 7:05 am
Different thickness rotors is only a problem with fat ones and new pads that are on the limit of manu tolerances....then you need to think laterally to solve the problem.
PaulD
Posted : 06/07/2012 7:11 am
Cynic-al whats the best way to true the rotor?
I did think about squishing it in a vice. But I don't have a vice.
Posted : 06/07/2012 8:11 am
you can buy rotor truing tools or you can just use a big adjustable spanner and bend it GENTLY back into place. Hope rotors are awesome though i have had 2 sets on 2 bikes and cant fault them.
Posted : 06/07/2012 8:15 am
[url= http://www.bikeradar.com/mtb/gear/article/video-workshop-how-to-fix-a-bent-disc-brake-rotor-34369/ ]Video guide here.[/url]
It's an easy job, save the cash for some other bits 🙂
APF
Posted : 06/07/2012 8:18 am
Use one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=47407 ]these[/url].
Posted : 06/07/2012 8:19 am
No, use one of these
[url= http://toolspot-static.co.uk/i/3816z.jp g" target="_blank">http://toolspot-static.co.uk/i/3816z.jp g"/> [/img][/url]
APF 😉
Posted : 06/07/2012 8:54 am
