disc rotor wear
[Closed] disc rotor wear
2 Users
just noticed that the rear disc is getting swept/worn on the 'spokes' by about 10mm front is fine. SLX caliper with pads from uber maybe , could the pads be too deep?(they fit into caliper ok) any other possible reasons?.160 rotor BTW That ad>>> has just started a disco brakes ad! 😯 its like im being watched thanks
Posted : 31/05/2015 4:16 pm
Check the washers on the calliper mounting bolts, sometimes they need to be pushed away from the rotor as you are tightening them up
Posted : 31/05/2015 4:27 pm
