Hi,
Almost had it once, unfortunately ebay and WiFi mojo wasn't exactly in sync.
Lost by pennies...
Since then looking after disc, carbon frame with a set of traits that are not so easily obtainable in one package.
1. Square or square-ish geo with ETT around 565-570mm and seat tube around 580mm tops.
2. BSA BB shell.
3. 135x10 rear spacing.
4. Tall-ish head tube, 170+mm.
5. With at least 28c (ideally 30c) capacity.
These are option minimum.
Rest of the things will account into ideal world situation.
Mudguards mounting points, top pull front mech, 27.2 seatpost, 32c capacity...
After a bit (quite a bit of digging) looks like that the only close minimum option is PX RTD-80 but not sure if it will accommodate anything bigger than 25c. There is also PX XLS but XL might be a tad too close to my jewels on the top tube.
New, second hand not really bothered...
Any suggestion?
Cheers!
I.
Bump...
Anybody? Anything?
Cheers!
I.
Nothing springs to mind. Hows the budget? Filament will build what you want in the UK, spend but amazing.
http://www.filamentbikes.com
Genesis datum maybe?
On-One Bish Bash Bosh? Has a 12mm rear axle though...
Very good call ChrisA!
Looks interesting on paper.
Just need to catch 2016 model as 2017 already have PF86 bottom bracket shell.
Filament looks like way to go but rather out of budget reach I'm afraid.
Cheers!
I.
PS
Just checked... 2016 was PF86 as well 🙁
