Disc brake and moun...
[Closed] Disc brake and mounts .....HELP !
13 Users
I'm not sure if I'm being a bit thick here it what but can you help......
New Shimano deore 4 pot brakes.
Front fitted to a yari with a post mount.
203mm disc and adapter leaves me with this ......
[url= https://i.postimg.cc/J0gL43vn/IMG-20190611-171845.jp g" target="_blank">https://i.postimg.cc/J0gL43vn/IMG-20190611-171845.jp g"/> [/img][/url]
The caliper is clearly not sat correctly over the disc ??
Any ideas ?
Posted : 11/06/2019 6:21 pm
Yari probably has a 180mm post mount so you only need a +20 adaptor.
Posted : 11/06/2019 6:25 pm
Yeah what Simon says.
Posted : 11/06/2019 6:31 pm
Damn !!!!
Posted : 11/06/2019 6:32 pm
So what mount do I need then ?
Posted : 11/06/2019 6:33 pm
A 180pm>203pm
Or just a standard +20 and a few washers.
Posted : 11/06/2019 6:36 pm
Pretty sure it's a post mount for 160. 180 on my Yaris and using a 20mm adapter
Posted : 11/06/2019 10:34 pm
You anywhere near Glentress/Inners? I've got a fair few adapters you can play with, must be one which would fit
Posted : 11/06/2019 10:37 pm
Yari is 180, so you need a 180-200.
That adapter looks wrong too - the Shimano ones I have are bolt through with longer bolts.
Posted : 11/06/2019 10:40 pm
That adapter looks wrong too – the Shimano ones I have are bolt through with longer bolts.
The +20mm mounts are bolt through. That mount is correct for 160->203.
Posted : 11/06/2019 10:44 pm
223mm rotor. sorted!
Posted : 11/06/2019 10:56 pm
Just to be completely sure... Is your disc definitely 203 and not 180?
This is mine with 180. The mounts look different though.
rotor
Posted : 11/06/2019 11:08 pm
https://images.app.goo.gl/w5cQ6F7QBLJTvR1W7
Posted : 11/06/2019 11:09 pm
I did exactly the same last week. Bought a 203 rotor and the straight post adaptor. Rock shox yari mount is 180 so you need the 180 to 203 adaptor:
Adaptor
Posted : 11/06/2019 11:27 pm
Yes, I.... ummm... have a friend who made the same mistake. I wonder how many +40 mm adapters there are sitting in spare parts boxes around the world.
Posted : 12/06/2019 1:17 am
Hayes used to make such a thing?
Posted : 12/06/2019 7:51 am
