I've always had forks with IS caliper mounts. I now have a Rockshox SID fork wih a post mount. What adaptor do I need for a 200mm rotor?
Does anybody know if you can use a 203mm adaptor with a 200mm rotor?
No, the pads will stand proud of the rotor by 1.5mm and as the pads wear they'll develop a lip on the outer edge which after a while will touch each other and your brake will stop working..
OP are you sure you want to put a whopping 200mm rotor on a SID fork which is a lightweight xc fork?
Short answer is no, I don't, but the longer answer is that it's cheaper than the alternative and still within SRAM's recommended maximum 😉
i didnt realise an xc fork would be allowed to run such a big rotor...i would have thought 180mm would be the max.
Float 32s allow for a 203mm rotor....
