Disc Adapter diffic...
[Closed] Disc Adapter difficulties
6 Users
Just put a 180mm disc on the backwheel of a bike and so fitted an IS to PM 180mm adaptor.
Put it all together and caliper is about 5mm too far out so only gripping outer edge of disc.
Am I being very stupid?
What have I missed?
Posted : 13/07/2013 5:37 pm
is it the right way round?
Is it 185?
Pics may help
Posted : 13/07/2013 5:38 pm
Avid discs are 185 I think, is that what you have?
Posted : 13/07/2013 6:09 pm
If you are using an Avid brake it may be expected a 185mm disc but if you've fitted a 180 that might explain the problem. But it would only be about 2.5mm out, might be enough for it not to work well.
Posted : 13/07/2013 6:11 pm
Thanks for thoughts but it is a 180mm disc with 180mm neatly stamped on it
Posted : 13/07/2013 6:48 pm
Is it avid though? I thought the bloody stupid trialign thing messes up their sizing?
Posted : 13/07/2013 7:01 pm
I assume its a rear adapter? They are different to the front ones on spacing if I recall. Ie a 180 front caliper is the same spacing as a 160 rear.
Posted : 13/07/2013 8:32 pm
Balls!
Posted : 13/07/2013 8:35 pm
I'm guessing the adapter is upside down and the calliper will grip the disc much further round but 5 mm further on. It's easy done!
Posted : 13/07/2013 8:40 pm
