Direct mount chainr...
[Closed] Direct mount chainring bolts
4 Users
Anyone know where to source direct mount chainring bolts that are m8 for a SLX crank, with a torques head, that aren't made of cheese please?
Posted : 11/07/2021 7:49 am
Direct mount rings don't use bolts*. That's the whole point. If you are mashing the normal ones then either your tool is worn, the threads need cleaning or hulk needs putting back in the box 😀.
* Unless you have a direct mount spider and normal rings.
Posted : 11/07/2021 7:56 am
Oops, I mean the crank bolts that go into the crank rather than having a 'nut' on the other side.
Posted : 11/07/2021 8:00 am
The plastic preload one?
Posted : 11/07/2021 8:23 am
They are just normal chain ring bolts.
https://www.sjscycles.co.uk/chainsets/shimano-deore-xt-fcm780-inner-chainring-fixing-bolts-m8-x-85mm-1mm-9810/
Posted : 11/07/2021 6:43 pm
I found those stripped out of my SLX cranks, very disappointing.
Posted : 11/07/2021 8:24 pm
I don't specifically mean the bolts Jimmy linked.
Just that 3 out of 4 of the holes stripped out on the crank, using the stock bolts.
Posted : 11/07/2021 8:26 pm
